American Muscle wheels vibration problem
Old 04-27-2011, 06:13 PM
69MustangCoupe393cid
69MustangCoupe393cid's Avatar
The car drives perfectly straight still, and honestly I'm starting to think a tire is out of round or something, I feel it even at lower speeds. I'll check for washers right now.
69MustangCoupe393cid is offline
Old 04-27-2011, 06:30 PM
Snakebite64
Snakebite64's Avatar
Weird, before the rims at AM smooth as glass now I have a slight wobble above 50mph.
Snakebite64 is offline
Old 04-27-2011, 11:17 PM
TRUEBLUE3934
TRUEBLUE3934's Avatar
I bought (4) 17x9 Bullitt wheels from AM and a pair of 17x10.5 Bullitt wheels from AM and all of them were great!
I would double check the balancing first.
TRUEBLUE3934 is offline
Old 04-28-2011, 05:40 AM
uberstang1
Chupacabra
uberstang1's Avatar
Originally Posted by WhiteFoxGT
Alignments wont really cause a shake unless its freakin driving sideways. Is the shake at higher speeds 50+? If so, Get the tires balanced with a good machine
+1 alignment wont cause a shake, especially if it drove fine before the wheels tires and springs, just get them balanced.
uberstang1 is offline
Old 04-28-2011, 07:21 AM
teej281
4.6L Section Moderator
teej281's Avatar
Well he installed lowering springs and the cc plates could have been moved during installation. I really don't think it's the wheels themselves.
teej281 is offline
Old 04-28-2011, 07:49 AM
BraMas
BraMas's Avatar
Originally Posted by Moonshine
Did you remove the silly washers on the hub?
Are you talking about the washers that are put on during assembly @ Ford? Even if those happen to still be on they are not going to cause any vibration.
I'm gonna say one of the rims have a bad balance. I know some guys on SVTP are complaining about all the wheel weights needed on the AM rims to make them balance.
Also maybe one or the tires might be bad I know they are new but it is possible
BraMas is offline
Old 04-28-2011, 08:21 AM
uberstang1
Chupacabra
uberstang1's Avatar
Is the step spacer installed correctly on the new after marke CC plates?
Old 04-28-2011, 10:08 AM
Kmelfi11
Kmelfi11's Avatar
My old rims from am had a slight shake and never really noticed it until I put other rims on. Glad I went with BBS for my new rims!
Kmelfi11 is offline
Old 04-28-2011, 10:49 AM
  #19
teej281
teej281's Avatar
Kmelfi got new wheels?!
teej281 is offline
Old 04-28-2011, 11:26 AM
  #20
smitty2919
smitty2919's Avatar
Wrong. It depends on how bad this wabble is. Do as Moonshine and I are suggesting. Take the wheels off and look for the washer on at least one of the wheels studs.
It happened to me when I got 18" saleen wheels from Cruzin Concepts. I also thought about a balancing issue, using right lug nuts, torquing the nuts right etc. It all came down to taking those washers off. Especially if you know you have stock untouched brakes. Chances are it's still on there.
You would be dumb NOT to check since it's free and only takes 30 min to check all the wheels.
Here, Page 10 post #96....pics are worth 1000 words. These were from Cruizin Concepts, but I wouldn;t doubt if they use the same vendor.
https://mustangforums.com/forum/4-6l...inions-10.html
smitty2919 is offline
Quick Reply: American Muscle wheels vibration problem
