Car moves forward when you put transmission into park
Old 05-02-2011, 12:29 PM
Toms_2003_Stang
Toms_2003_Stang's Avatar
Default Car moves forward when you put transmission into park
Whenever you put my g/f's GT into park it moves a little forwards then stops.....is this normal with the 5spd auto?
Toms_2003_Stang is offline
Old 05-02-2011, 03:36 PM
hawkeye18
hawkeye18's Avatar
It is normal with EVERY auto.
When you put it in park, there is a little latch (it's actually technically a pawl) that extends into a gear, which has a certain number of teeth. That pawl engaging one of the teeth in the transmission is what sets the park - the pawl is mated to the case, the gear on the output shaft.
If, when you shift into park, the pawl is not exactly lined up with one of the teeth, the car will roll forward (or backward) until the pawl engages a tooth on the gear. This is why sometimes it will roll forward an inch, sometimes 5-6 inches.
It's certainly nothing to be worried about - that transmission simply happens to have fewer teeth on its parking pawl gear than others, which means the car will roll more than others until it finds a valley between teeth.
Keep in mind also that when parked on a hill, this pawl is the only thing keeping the car from moving; the entire weight of the car is on that pawl. The greater the incline, the more weight on the pawl. This is why sometimes it can be difficult to shift out of park on a hill. This is also why you are supposed to set the parking brake when parking on a hill, to keep the weight off that pawl (which will snap, and that's an expensive fix!).
hawkeye18 is offline
Old 05-02-2011, 04:44 PM
Toms_2003_Stang
Thank you for responding Hawkeye....
Old 05-02-2011, 04:50 PM
Yes, it's normal and I would recommend using the parking brake as well. Less wear on the gear teeth and less likely to "let go"
Old 05-02-2011, 08:21 PM
Toms_2003_Stang
Only time we use the parking brake is when we park her on a hill......
Old 05-03-2011, 12:21 PM
Mishri
Mish-ogynist
Mishri's Avatar
yep, that is what is recommended, only on inclines/declines, not on flat surfaces... i'm not sure why they say that, but i follow that as well.
Mishri is offline
Old 05-03-2011, 12:46 PM
Nuke
Nuke's Avatar
Normal and most pronounced when on a hill. Anything more than about 6"-12" of movement would be a problem, IMO.
Nuke is offline
Old 05-05-2011, 09:14 AM
alkemist
alkemist's Avatar
Also a good reason why not to park too close to the curb. The lurch is minimal but you never know..
alkemist is offline
djbigskrilla
09-20-2022 01:04 AM
Goldenpony
08-19-2015 08:46 PM
Greyshot
08-15-2015 03:32 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Car moves forward when you put transmission into park
