Largest rear tire
Old 05-09-2011, 06:02 AM
slickman
slickman's Avatar
Default Largest rear tire
This has probably been asked a million times.. Whats the largest tire I can fit in the rear? I also need what rim size as well, with offset and rim width.
slickman is offline
Old 05-09-2011, 07:10 AM
Nuke
Nuke's Avatar
Are you talking width, height or both? Also, are you lowered or on a stock suspension? Remember that going with taller (larger OD tires) is equivalent to regearing so choose wisely.
I have a spreadsheet that you can load your stock wheel size including offset and any other combination and it'll give you both data and figure comparisons which should help. PM me with your e-mail and I can forward it.
Nuke is offline
Old 06-16-2011, 06:57 PM
Borzi
Borzi's Avatar
Default tire size chart
Hi Rick, I would be interested in that tire size chart. Could you email me at christianborzi@gmail.com?
Thanks!
Borzi is offline
Old 06-16-2011, 07:24 PM
lazyboy31614@aol.com
lazyboy31614@aol.com's Avatar
I'm currently running a 305/45 18 on an 18X10 inch rim with +40mm offset. I'm lowered about an inch and a half in the rear. No problems with rubbing.
lazyboy31614@aol.com is offline
Old 06-17-2011, 02:28 AM
808muscle
808muscle's Avatar
Dont forget tire brands differ in true width. Nitto tires are not as wide as other brands the same size.
808muscle is offline
Old 06-17-2011, 03:57 AM
Fresh_GT
Fresh_GT's Avatar
Black_N_Blown's running 315 NT05s in the rear on 20x11" wheels. Plus he's got a 2"+ drop. Its tight, but you could probably fit 325 in the rear
Fresh_GT is offline
Old 06-17-2011, 12:40 PM
MustangFirstCar
MustangFirstCar's Avatar
Didn't Diabolical fit ridiculously wide tires on the back of his car with a little modification to the sway bar or something? I'll see if I can find the thread.
MustangFirstCar is offline
Old 06-17-2011, 01:02 PM
Alec
Alec's Avatar
Yeah I wanna say it was like a 315+
Alec is offline
Old 06-17-2011, 02:01 PM
forensicsteve
forensicsteve's Avatar
I did have M&H 325s on the rear at one time. Car had very limited street use. They poked out the side, just a tad
For the strip, car had some humongus Hoosiers. Actually had to take a hammer to the fender wells at the strip, because they were rubbing.
Get an idea from this pic, just how fat they were, also 29 inches tall
compared to stock
forensicsteve is offline
Old 06-17-2011, 02:44 PM
mayo
mayo's Avatar
with your current drop, I would say you have one of two options.
295/45/18 I have seen with up to 1.5in of drop, so i am sure they would work or a 305/40/18 should go in there without modification...both of which nitto currently sells.
offset should stay around the 40mm mark to insure that they don't rub.
Personally if I was you, I would go 285/40/18. With a drop they look the best imo...check out member Dprived's ride to get a look!
hope this helps....and
GET THE CHROME COBRA R'S...THEY WOULD LOOK HOT ON THAT BLUE!
that is all...lol.
mayo is offline
Quick Reply: Largest rear tire
