Need heads and intake torque specs....
Old 05-13-2011, 11:54 AM
AntiRiceRacing
AntiRiceRacing's Avatar
Default Need heads and intake torque specs....
What would the torque specs be? It is a aluminum intake and aluminum heads if that makes a difference....
AntiRiceRacing is offline
Old 05-13-2011, 11:08 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
intake is around 19. It doesn't really matter as long as you follow a sequnce and go over them with a ratchet about 3 times.
The heads are around 75 I belive. I always follow a torque spec book for heads.
TrimDrip is offline
Old 05-13-2011, 11:15 PM
Venomantidote95
Venomantidote95's Avatar
Torque specs are per fastners! mostly, the intake will be ok between 19-24 lbs anymore and you risk a crack!
the heads will be by the bolts spec and done in the correct order!
Venomantidote95 is offline
Vrooom
02-21-2016 05:25 PM
LivingInThePast
09-16-2015 12:20 PM
EASTIDEE123
09-14-2015 03:52 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Need heads and intake torque specs....
