Side Door Panel Vinyl Falling Off
Old 06-08-2011, 04:02 PM
JohnTN
JohnTN's Avatar
Default Side Door Panel Vinyl Falling Off
The black perforated vinyl on the passenger door is coming off above the arm rest on my 2006 GT. It has come lose at the top and rolled down onto the arm rest.
Any suggestion on what kind of adhesive to use to glue it back up?
John
JohnTN is offline
Old 06-08-2011, 04:08 PM
pascal
S197 Section Modder-ator
pascal's Avatar
This thread should help you.
https://mustangforums.com/forum/2005...gging-fix.html
pascal is offline
Old 06-08-2011, 08:20 PM
Nuke
Nuke's Avatar
Thanks, pascal. You saved me from having to hunt that down.
Nuke is offline
Old 06-09-2011, 06:28 AM
MADSCOTSMAN
MADSCOTSMAN's Avatar
I'm trying to figure out what to do with mine on the driver's side as well, other than trying to pull an edge down and risk ripping it. My problem is that it is coming off the door in the very middle of the panel (looks like a few giant bubbles), and all the outside edges are still firmly adhered to the door panel. Any suggestions out there?
MADSCOTSMAN is offline
Old 06-09-2011, 07:01 AM
Nuke
Nuke's Avatar
For the bubble problem, I'd consider injecting a small amount of adhesive with a needle-style applicator and rolling those spots flat rather than going thru the entire "remove and replace" effort.
Nuke is offline
Old 06-09-2011, 07:07 AM
MADSCOTSMAN
Funny you should mention that, I'm diabetic so I thought about using one of my syringes to "inject" some adhesvie through the leather, just wasn't sure if the adhesive was thin enough in consistency to push through a syringe. Thanks for the idea, maybe i'll give it a try.
Old 06-11-2011, 11:28 PM
Mineral_GT
Mineral_GT's Avatar
My middle panel is also bubbling. Let me know if u try this
Mineral_GT is offline
Old 06-12-2011, 07:31 PM
pascal
pascal's Avatar
Don't give him (Nuke) any ideas on what you can do with syringes...
Crack is bad enough, lol.
pascal is offline
Old 11-22-2013, 11:12 AM
pmach1jeff
pmach1jeff's Avatar
Had the same problem with my panels falling off and poor results trying to glue back on with trim adhesive. Then I found a door panel upgrade kit in a Mustang magazine from a company called Predator Mustang. I ordered a red kit to match my paint and installed it one evening. It looks beautiful and to my surprise I took a first place trophy at a the next car show. I entered I highly recommend this as an alternative to glue. Here is a pic of my panel with kit.
pmach1jeff is offline
PaulH2
20
01-31-2016 09:48 AM
09-25-2015 06:58 PM
Gkid182
09-22-2015 08:17 AM
accarter
09-21-2015 11:56 PM
2k232
09-16-2015 10:28 AM
Quick Reply: Side Door Panel Vinyl Falling Off
