Bad brake sensor?
Old 06-10-2011, 01:28 AM
Vscout
Vscout's Avatar
Default Bad brake sensor?
My onboard computer keeps giving the "Low brake fluid" error. I have had it since day one of purchasing the vehicle. I called the dealership and they assured me the brake pads were to spec (I know the error will sometimes come when brake pads are worn). I also topped off the brake fluid. The error will tend to turn on when I get a car wash and the wheels are scrubbed. I have not taken the pads off to see their wear but it seems like the brake sensors are not working correctly.
Any advice anyone can give?
Thanks.
Vscout is offline
Old 06-10-2011, 07:59 PM
SpartaPerformance
SpartaPerformance's Avatar
There are no brake "sensors". If the red brake light comes on when washed or raining you may have a bad ground/wiring in your parking brake cable system
SpartaPerformance is offline
Old 06-10-2011, 08:23 PM
Vscout
Vscout's Avatar
It doesn't come on only when exposed to water though. Often times it will come on randomly.
Vscout is offline
Old 06-11-2011, 07:36 PM
SpartaPerformance
Well then you may have a bad sensor in the master cylinder reservoir, the light will illuminate when the fluid level gets low also.
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
mungodrums
10-07-2015 04:01 AM
DoctorScary
09-09-2015 07:53 AM
Quick Reply: Bad brake sensor?
