Code P0340 cam position sensor
Old 06-27-2011, 02:43 PM
chking37
chking37's Avatar
Default Code P0340 cam position sensor
I have a 1996 Gt Vert with 200K on it.
It threw a code of P0340 (cam positon sensor)
My question is, Where is the sensor located?
I was going to change it first to see if this fixes the problem. I've also read that the alternator can trip this code but since the sensor is $30 and the Alt is $200, I'm hoping the cheaper one does the trick.
Thanks in advance for your help.
chking37 is offline
Old 06-27-2011, 03:39 PM
jwog666
jwog666's Avatar
mine used to throw that code when the temps were above 85, replace the sensor = fixed. the sensor is located on the left hand side of the engine front cover, one bolt holds it in place. its a 5 min job max.
jwog666 is offline
Old 06-27-2011, 05:22 PM
chking37
chking37's Avatar
I must be blind. All I see are the coil packs and power steering res.
Is it lower down?
chking37 is offline
Old 06-28-2011, 01:32 PM
jwog666
jwog666's Avatar
Is it lower down?
yes its lower down below the coil packs, you are very close just look a little closer.
here is a pic but you will need to zoom in a bit, sorry its line art.
jwog666 is offline
Old 06-28-2011, 04:31 PM
chking37
chking37's Avatar
ah ha, found it hiding behind the power steering res.
thanks for the help.
chking37 is offline
Jb145700
08-21-2022 06:37 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
trashxtrash
09-20-2015 10:49 PM
Big Al's 03
09-16-2015 07:31 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: Code P0340 cam position sensor
