Rear window adhesive?
Old 06-28-2011, 10:56 AM
Thundersteel
Thundersteel's Avatar
Default Rear window adhesive?
I've got an '08 vert. The bottom corners of the top, on the outside of the rear window, are starting to pull away from the rear window glass. Thankfully, I have no leaks--yet. Is there an adhesive I can use to repair this before it gets any worse? Or should I take it to the dealer or a convertible top specialist for the repair?
Thanx for your help.
Thundersteel is offline
Old 07-05-2011, 04:30 PM
TPony
TPony's Avatar
I would recommend to take to a specialist..not sure the material would take any regular glue, but special glue.
TPony is offline
Old 07-08-2011, 04:56 PM
Thundersteel
I found this thread on a Corvette forum. I bought the glue online, and once I get it, I'll try it. It can't hurt!
http://forums.corvetteforum.com/c5-g...-refasten.html
Old 07-14-2011, 09:45 PM
Thundersteel
It worked! Even with FL sun/humidity and daily thundershowers, it's still holding!
Not bad for $20!
Old 08-14-2012, 11:33 PM
Javdog
Javdog's Avatar
i need this glue, how is it holding up
Javdog is offline
Old 08-15-2012, 08:20 AM
Thundersteel
After a year later, it's still working!
Old 08-16-2012, 11:33 AM
Javdog
Javdog's Avatar
Thank you Thundersteel I ordered it yesterday and I'm defiantly giving it a try this will be better then having to replace the whole top
Javdog is offline
Old 08-17-2012, 09:20 AM
Thundersteel
Make sure you put tape on the convertible top where you don't want the glue to go. It dries white, and it you're not careful, it can get messy. Just take it slow, and don't use too much glue.
Old 08-17-2012, 09:34 AM
Dubwhat
Dubwhat's Avatar
The mustang I bought has a Convertable top which the window has come out of the top an starting from the bottom. I found a glue at Walmart called Goop RV sealant/adhesiv. I tested it on the bottom following the directions on the tube and it worked. I took a razor to clean it up then ran one more bead on it to make it look good and so far it's great. It's holding nice and solid with no signs of coming apart. I can post pics if you'd like. The tube was 3$
Dubwhat is offline
Old 08-18-2012, 04:33 PM
scan1959
scan1959's Avatar
Check this out! Last month I had a brand new 2012 GT convertible in my shop with this problem already.
Tell your friends to watch their back windows. Get them replaced if needed while still under warranty.
Scan
scan1959 is offline
Quick Reply: Rear window adhesive?
