5.0L Electric Fan Conversion
Old 09-03-2005, 12:26 AM
KrisSmithRocks
KrisSmithRocks's Avatar
Default 5.0L Electric Fan Conversion
5.0L Electric Fan Conversion (Post #1)
My Friend is selling these high output 3.8L Lincoln Electric Fans on Ebay that are very desirable for the electric fan conversion on Mustangs. He installed one on his car and notice a very real gain from not having to rotate that heavy clutch fan. Check it out
http://cgi.ebay.com/ebaymotors/ws/e...TRK%3AMEWA%3AIT
KrisSmithRocks is offline
Old 09-03-2005, 11:37 AM
stanglx2002
stanglx2002's Avatar
Default RE: 5.0L Electric Fan Conversion
links didnt work
stanglx2002 is offline
Old 09-03-2005, 12:48 PM
Soaring
I ♥ Acer
Soaring's Avatar
The myth that electric fans give you more horsepower is untrue. It robs your alternator of amps causing your engine to work just as hard to produce the amps necessary to produce the needed cooling as does a mechanical fan.
Soaring is offline
Old 09-03-2005, 03:34 PM
cammedlx
cammedlx's Avatar
Not really,theres tons of article's in mags that time and time again prove that a electric fan does improve hp,some more or less it just all depends on the the type of fan you had previous.
cammedlx is offline
Old 09-03-2005, 07:18 PM
fordguy17
fordguy17's Avatar
ORIGINAL: Soaring
not really. the electric fan isn't always running so it will give you a few horsepower especially in the upper rpms. it will give a some gas mileage too especially on the highway.
fordguy17 is offline
Old 09-03-2005, 08:56 PM
luckythirteen13
luckythirteen13's Avatar
also, the alternator doesnt rob power if its working at 100% capacity or 10%. the alternator output is controlled by demand but the resistance needed to spin it is the same. and fordguy is right, depending on the weather, the fan isnt always on. in summer, mine will go on 2 times at the most in a 15 minute drive. in the winter, my fan never comes on
luckythirteen13 is offline
Old 09-03-2005, 11:46 PM
Quik
Quik's Avatar
also improves rotating mass. so it helps gain MPG
Quik is offline
Old 09-04-2005, 12:12 PM
FoxGT
FoxGT's Avatar
+ is easier to take off.
FoxGT is offline
Old 09-04-2005, 12:14 PM
stanglx2002
the less work the car has to do the more HP and MPG you will gain
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
tj@steeda
09-17-2015 07:32 PM
Quick Reply: 5.0L Electric Fan Conversion
