replacing clutch cable 83 5.0
Old 07-26-2011, 04:11 PM
DarrellWSharp
DarrellWSharp's Avatar
Default replacing clutch cable 83 5.0
I need some info replacing the clutch cable anything would be helpful.
DarrellWSharp is offline
Old 07-26-2011, 07:56 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Purchase a stock cable and replace. Its not hard to do.....
projectresto83 is offline
Old 07-26-2011, 08:24 PM
Js88lx
Js88lx's Avatar
easy just take off your cable and reverse process ti install!!!
Js88lx is offline
Old 07-26-2011, 08:56 PM
mustangGT86_05
mustangGT86_05's Avatar
google it, there are actually quite a few write ups on this matter.
mustangGT86_05 is offline
Old 07-26-2011, 08:58 PM
mustangGT86_05
http://www.americanmuscle.com/clutch-cable-install.html
first result, this is pretty much the exact same thing
Old 07-27-2011, 10:42 AM
DarrellWSharp
Thanks for the help it got me started in the right direction.
Old 07-27-2011, 02:52 PM
DarrellWSharp
I found the clutch cable good and the problem is the plastic adjuster under the dash has stripped the teeth off. It looks like i will have to remove the mounting to replace it any information on this would be very helpful.
Old 07-27-2011, 06:36 PM
mustangGT86_05
its called a quadrant, they offer upgraded metal ones but can be a bit pricey
Old 07-27-2011, 07:13 PM
projectresto83
M.A.D. Motorsports
http://www.latemodelrestoration.com/...lutch-Quadrant
$30 and it works great. To get the stock plasic crap off its just easier to finish breaking it. Installing the aftermarket one is simple but its a tight fit.
djbigskrilla
09-20-2022 01:04 AM
Urambo Tauro
12-17-2016 03:30 PM
Jskeezy84
09-08-2015 01:40 AM
Takeiteasee
08-27-2015 03:59 PM
ponyride00
08-12-2015 01:57 PM
Quick Reply: replacing clutch cable 83 5.0
