96 Mustang ignition wont turn
Old 08-05-2011, 10:49 AM
brfan
brfan's Avatar
Default 96 Mustang ignition wont turn
Wondering if anyone has ever faced this. Out of nowhere, my ignition will not turn with the key in it. Wont even budge. I have tried making sure steering wheel isnt locking it, tried different keys... etc.
Looking for ways to get passed this so I can get the car home.
Thanks....
brfan is offline
Old 08-05-2011, 11:15 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
You need to call a locksmith, they will have the tools and knowledge to deal with it.
cliffyk is offline
Old 08-05-2011, 02:28 PM
B_Kurlovich
B_Kurlovich's Avatar
My car does this ever now and then I just kinda pull it back to acc and then it will go foward is yours a 5 speed?
B_Kurlovich is offline
Old 08-05-2011, 03:34 PM
brfan
brfan's Avatar
it is five speed... and i cant even get it to go back to acc position..
brfan is offline
Old 08-05-2011, 04:14 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
You can try squirting a bit of WD-40, CRC-556, or the like in there and then rocking the key back and forth--one or more of the pin tumblers may be stuck and the light oil might free it up.
But if any tumblers are broken you'll need a pro to get the lock assembly apart. By the book you have to turn the lock cylinder to RUN and push the cylinder release to get it out--locksmiths have tools that can break the tumblers and get the lock cylinder out.
This ruins the cylinder but they will likely have a replacement with them if you tell them you have a '96 Mustang when you call...
cliffyk is offline
Old 08-05-2011, 06:10 PM
Jtraversa2
Jtraversa2's Avatar
This has happened a couple times to me randomly and every time i lock the steering wheel. For me all you have to do is really muscle it around, a few times i had to start hitting it to get it to turn. I have a 2004 so it could be a completely different story and if thats the case you risk braking your key and having the shaft of it stuck in the ignition...
Jtraversa2 is offline
KEM Motorworks
08-14-2015 10:13 PM
daytooday
08-11-2015 09:22 AM
yurizx6r
08-11-2015 07:50 AM
89blueslug
08-10-2015 07:20 AM
Quick Reply: 96 Mustang ignition wont turn
