1969-1970 clutch pedal & Linkage
Old 08-06-2011, 07:45 AM
Stangman70
Stangman70's Avatar
Default 1969-1970 clutch pedal & Linkage
Hey guys, I am getting a clutch pedal and linkage off a 69 donor car to put on my 70 coupe which is an automatic. Will this pedal set up work? I know that I will have to trim my 70 pedal to get it to match, but I am wondering if the 70 has its own pedal. I have an interchange book, but I have seen guys use older pedals on new cars, 65 on a 68 for example. Will I have a problem with this?
Stangman70 is offline
Old 08-06-2011, 08:18 AM
2+2GT
2+2GT's Avatar
Why not just use both pedals from the donor car? The earlier pedals will not fit properly.
2+2GT is offline
Old 08-06-2011, 05:19 PM
Stangman70
Stangman70's Avatar
The 70 brake pedal is unique in that the rod that connects to the master cylinder has a round hole at its end where as the 69 is square. This could be true only for power brakes, which the car does not currently have, but I have the booster which will be applied at a later date.
Old 08-06-2011, 07:19 PM
2+2GT
2+2GT's Avatar
No, that's not the difference. The pushrod hole could not possibly be square, anyway, since it would not rotate. The 1970 power brake pedal was unique, in that the steel post for the pushrod was mounted about 1/2" higher up, because the 70 pushrod was straight, while the 67-69 was a teardrop.
1967-1969: 1970:
2+2GT is offline
Old 08-07-2011, 12:37 AM
Stangman70
Stangman70's Avatar
Thanks for the clarification. So could I use the 70 booster with the 69 pedal?
Old 08-07-2011, 08:32 AM
2+2GT
2+2GT's Avatar
Absolutely not. The pushrod would not line up properly. 70 boosters must use 70 pedal. The 69 pedal is reproduced, but not the 70. Both boosters are reproduced, though.
2+2GT is offline
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ThatJuanStang
09-25-2015 08:01 AM
ccdguy
09-19-2015 05:20 PM
Quick Reply: 1969-1970 clutch pedal & Linkage
