99 Mustang drivers side Door won't shut
Old 08-09-2011, 05:23 PM
eonblueapocalypse
eonblueapocalypse's Avatar
Default 99 Mustang drivers side Door won't shut
Hello, I have a 99 ford mustang and my drivers side door won't close. It appears that where normally the striking pin would cause the door lock mechanism to lock into place (close the door) it instead does not lock into place. To be clear, I have verified that the mechanism is not in a closed position, it does not bounce back at me and I have tried forcing it closed with a tool, it is just no longer locking in place when actuated.
Also, sorry if my jargon is way off. I am no mechanic.
eonblueapocalypse is offline
eonblueapocalypse
My question is which part do I need to replace... sorry if that wasn't clear
Old 08-09-2011, 06:16 PM
3.0Taurass
3.0Taurass's Avatar
try spraying wd40 on the latch thing first. My taurus had the same problem in january and wd40 fxed it
3.0Taurass is offline
Old 08-09-2011, 08:39 PM
eonblueapocalypse
Sorry, that does not help. I have tried.
Old 08-09-2011, 08:55 PM
DRAGUL
DRAGUL's Avatar
Is the door sagging? You could try picking up on the door and see if it will latch. One of my old cars started doing this when the door pins got to worn out. The door dropped to much to hit the pin correctly. Good luck finding the problem.
DRAGUL is offline
Old 08-09-2011, 10:02 PM
JRad405
JRad405's Avatar
so the latch is stuck open?
JRad405 is offline
Old 08-10-2011, 07:36 AM
eonblueapocalypse
Sorry, no. There is a mechanism that makes contact with that little bar on the inside of the door, That mechanism does not lock into place. It moves freely back and forth it just doesnt lock. On the passenger door I can push it back and it locks into place, on the drivers side door I push it back and it does not lock into place. I need to know whether I need to replace that mechanism inside the door or whether there is something else connected to that that causes it to lock.
inyadreems
08-21-2015 09:10 AM
MtnMustang
08-16-2015 08:07 PM
KEM Motorworks
08-14-2015 10:13 PM
drumhedd2005
08-13-2015 09:59 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: 99 Mustang drivers side Door won't shut
