clutch chatter on a new clutch normal?
Old 08-14-2011, 01:37 PM
IRSmart
IRSmart's Avatar
Default clutch chatter on a new clutch normal?
i've never felt a *brand* new clutch before. on the spec stage 1 that i just installed friday, when i'm letting the clutch out, while it's grabbing, the car is what i would imagine is called clutch chatter. it's not a smooth disengage, but it only happens when i'm going into first. shifts from 2nd to fifth seem normal. is this a symptom of something wrong, or is this normal for the clutch break in?
IRSmart is offline
Old 08-14-2011, 10:33 PM
kugzgt
kugzgt's Avatar
did you get your flywheel resurfaced?
kugzgt is offline
Old 08-14-2011, 11:09 PM
IRSmart
IRSmart's Avatar
the flywheel was brand new also. a guy on the corral said that his spec stage 1 did the same thing for 500 miles, then it acted normal. i guess it's just in the break in period.
IRSmart is offline
Old 08-14-2011, 11:34 PM
kugzgt
kugzgt's Avatar
Yeah u will have a little bit of chatter during the break in period. It should go away tho
kugzgt is offline
Old 08-15-2011, 02:01 PM
Andy13186
Andy13186's Avatar
I actually just got a new clutch, and flywheel resurfaced too,
i am noticeing some shudder also during enguagement, mainly in 1st..
hopefully it does go away. I would call it a shudder not chatter in my case. If i start from a stop in 2nd you can really feel it.
Andy13186 is offline
Old 08-16-2011, 05:36 AM
uberstang1
Chupacabra
uberstang1's Avatar
Usually you will get some chatter till broken in.
uberstang1 is offline
Old 08-17-2011, 11:59 AM
BlackMage
BlackMage's Avatar
Spec is known for chatter in their clutches. i have a spec stage 2 and it chattered like a **** with a new flywheel. give it time to break in and it will slowly go away.
BlackMage is offline
Old 08-18-2011, 02:50 PM
IRSmart
IRSmart's Avatar
it's already started getting better, even with only 50 miles on it.
IRSmart is offline
Thunderball
15
11-22-2015 11:49 PM
breaking
10-02-2015 01:27 PM
guitarman376
09-30-2015 05:54 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: clutch chatter on a new clutch normal?
