fuel reset button?
Old 09-07-2005, 12:01 AM
ping4010
ping4010's Avatar
Default fuel reset button?
My '91 GT turns over, but the engine gets no fuel. I have checked the fuses, and they are fine. When I turn on the key (without starting it) I do not hear the fuel pump turn on. I am holding off taking it in as a last resort. I have heard of the emergency shutoff on the fuel pump being set off by slamming the hatch, and the solution was to hit the fuel reset button. Is there a fuel reset button, and--if so--where can I find it?
Thank you.
ping4010 is offline
Old 09-07-2005, 12:12 AM
sc94gt
sc94gt's Avatar
Default RE: fuel reset button?
Mine is located in the trunk behind the driver's side tail light.
sc94gt is offline
Old 09-07-2005, 12:19 AM
stanging
stanging's Avatar
Yes there is a fuel pump switch, it is in the trunk. Should be near the left trunk lid hinge, if it's a 2 door, or under the trunk latch on 3 door(Hatchback), or in the spare tire well.
Hope this helps.
stanging is offline
Old 09-07-2005, 03:06 PM
ping4010
ping4010's Avatar
Thanks a lot for the help guys. The button was triggered, however still no vroom vroom. Off to the shop.
ping4010 is offline
Old 09-07-2005, 05:40 PM
vfast
I ♥ Acer
vfast's Avatar
man atleast try to fix it
vfast is offline
Old 09-07-2005, 07:30 PM
90GTRagtop
90GTRagtop's Avatar
Have you checked your fuses and fuel pump relay? Cheap fixes if they are the problem.
90GTRagtop is offline
Old 09-08-2005, 12:07 AM
5.0sTheWayToGo
5.0sTheWayToGo's Avatar
with the fuses in check each side of the fuse while it is in the box..because i made the mistake of only checking on side of the banking and the test like cam on everytime..i didnt check the other side where it had to flow to..and i had this same problem and sure enough when i checked it again the test light didnt light up on both sides of the fuse teeth and i took it out and there was a very small crack in it..so i had a bad fuse and the same thing your desctribing
5.0sTheWayToGo is offline
lincolnshibuya
07-05-2020 03:05 AM
firehorse02
11-16-2015 11:28 AM
lincolnshibuya
10-06-2015 08:45 AM
Sixx
10-05-2015 07:36 PM
09-30-2015 12:39 PM
Quick Reply: fuel reset button?
