Turn Signal flasher location on 03 GT?
Old 09-08-2011, 12:45 AM
supermario
supermario's Avatar
Default Turn Signal flasher location on 03 GT?
Hello, sorry for the dumb question but where is the turn signal flasher located on a 03 GT? I looked under the dash but couldnt seem to find it? My blinkers stopped working, so Im assuming thats the problem. Thanks
supermario is offline
Old 09-08-2011, 12:25 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Have you checked the fuses? Fuses #13 and 18 in the central junction box are dedicated feeds to the flasher module.
The flasher module is located near the OBD2 data connector in the center dash:
cliffyk is offline
Old 09-09-2011, 09:09 AM
black2010
black2010's Avatar
It uner the dash to the right of the steering wheel. I want to say it's closer to the center console than the steering wheel. Lay on your back and look up under the dash there and you can't miss it. Mine was yellow but I've seen some that are black.
black2010 is offline
Old 09-09-2011, 10:09 PM
supermario
supermario's Avatar
Found it, it was yellow but my repo was black. Only thing, I tried to remove the box that the flasher is in but cant get it out. I just plugged the flasher into the plug, so there working now but i didnt mount it properly. How do you remove that box that the flasher sits in? I tried to remove it but it seemed to be stuck.
jwog666
12-27-2021 08:09 PM
lovesilver
Members Mustangs
05-09-2019 09:18 PM
09-27-2015 03:16 PM
logan409
09-26-2015 07:43 PM
jc409
Convertible Tech
09-26-2015 08:28 AM
Quick Reply: Turn Signal flasher location on 03 GT?
