Last edit by: IB Advertising
Browse all: Ford Mustang GT Steering & Suspension Guides
- Ford Mustang V6 and GT 2005-2014: How to Replace Front and Rear Lower Control Arms
Step by step instructions for do-it-yourself repairs.
Replacing rear lower control arm bushings
I have a set of "granatelli motorsports" upper and lower control arms (NON-weight jackers) they have poly bushings well after some abuse and make lack of grease some of the bushing broke. I'm replacing them with delrin bushing anyway....
I need to replace JUST the bushings in the lower control arms... Would it be easier to remove the entire control arm and replace the bushings and re-install
or
would it be possible to replace the bushings one by one with it still installed in the car just loosening up the bolts and removing and replacing with the new bushings
or
If they are poly/poly LCA's and poly UCA's and were on MY car, I would pull both sets off and get ones with better geometry
Can you give us a link to the specific arms that you have on your car? Both uppers and lowers, please?
Jazzer
Jazzer
or
or
+1 on just replacing them. Our Elite Series control arms (tubular chrome moly with Energy Suspension bushings) are $179 for the set of four with the MF discount. http://www.uprproducts.com/mustang-c...nsion-kit.html
If your going to replace them I would make sure at least one end of the control arm has a spherical bushing (hiem joint), control arms with poly bushings on each end bind and can damage the torque boxes.
Yep, I really like our Pro Street setup that has a spherical bushing on one end and polyurethane bushings on the other end. Some people prefer poly/poly control arms to reduce NVH, but I happen to like the spherical/heim joints much better!
inyadreems
08-21-2015 09:10 AM
