3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Old 10-15-2015, 07:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Specifications & General Maintenance
Print Wikipost
Visor mounted garage door opener
Old 09-25-2011, 11:49 AM
LAsports01
LAsports01's Avatar
Question Visor mounted garage door opener
OK, I give. I have tried multiple ways to get my 2012 Visor mounted garage door opener to work and can't. I have tried it on a Wayne Dalton iDrive (2005 vintage), a LiftMaster all digital (2011), and a LiftMaster (2010). I can link any actual remote without issue.
I press the two outside buttons and get the LEDs to light up. Then I press the one button I want to use and it starts blinking slowly, just like the directions state. Just that it never synchs to any door. And yes I do press the garage door opener Learn buttons.
So has anyone else had issues? Does anyone see what I'm doing wrong? Thanks.
LAsports01 is offline
Old 09-25-2011, 01:36 PM
Chromeshadow
Chromeshadow's Avatar
I had no trouble programming mine to a Genie. Have you made sure that your key is on and engine off while programming the transmitter? You do not have much time to move from the car to the garage door opener then back to the car, have you tried having a friend help?
Chromeshadow is offline
Old 09-27-2011, 11:02 AM
craigandi
craigandi's Avatar
call the 1-800 number in the manual....they will walk you through each opener. I had an old stanley that seemed impossible. Took them two minutes.
craigandi is offline
Old 09-27-2011, 05:23 PM
LAsports01
LAsports01's Avatar
Default Still no luck
I guess when I get some more free time I will have to call the 1-800 number. And I tried key on engine off with driver door shut, then drive door open. Car inside the garage. Car outside. Same response . The LED blinks slowly as I hold the button down then does the rapid blinking timeout. :-(
b8checker
09-30-2015 07:11 AM
treesloth
09-28-2015 07:03 AM
09-25-2015 06:58 PM
09-25-2015 09:06 AM
tj@steeda
Steeda Autosports
09-17-2015 07:57 PM
Quick Reply: Visor mounted garage door opener
