SVT Forums
Oil Cooler O-rings
Old 10-23-2011, 04:52 PM
1998Slow 'Stang
1998Slow 'Stang's Avatar
Exclamation Oil Cooler O-rings
Does anyone know anything about these O-rings? I've the oil in the coolant, but no coolant in the oil scenario, which points to the oil cooler. (Yes, I know, I have a GT, but some on the 98's came with them for some reason.)
1) Can I get all the needed O-rings from the Ford Parts counter
2) Is there any difference between the 96-98 and the 99-01 ones
3) How much am I looking at for this stuff?
1998Slow 'Stang is offline
Old 10-24-2011, 05:00 AM
Blackvenom01
Blackvenom01's Avatar
yes if it has it ford will provide it...they are like 13 dollars one big one for the cooler and a smaller one for the shaft that the filter shrews onto which also holds the cooler on
dont wanna be negative but could be blown head gasket
Blackvenom01 is offline
Old 10-24-2011, 12:19 PM
1998Slow 'Stang
Yeah, I've thought about that too. But I'll continue to refuse the thought until it hits me in the face.....so to speak. If it ends up being the head gasket I'm going to track down some PI heads before I bolt the crappy NPI one back up.
At any rate, thanks for the info Blackvenom
Old 10-25-2011, 05:09 AM
Blackvenom01
hahah ya lets hope for the best those coolers oring have been known to go out...goodluck man
Old 11-04-2011, 03:38 PM
1998Slow 'Stang
I got my o-rings this afternoon, waiting for the fluids to cool off so I can drain them and not have my skin burned off. ~$50 from Speed Concepts 4V Oil Cooler O-Rings/Gasket and Tool.
Last edited by 1998Slow 'Stang; 11-04-2011 at 03:38 PM. Reason: Proof reading fail
Old 11-05-2011, 09:56 AM
Blackvenom01
make sure to keep your mouth closed when you pull the coolant hose off the cooler lol ..i got a mouth full lol
Old 11-05-2011, 11:55 AM
1998Slow 'Stang
Yeah, I should have keept my eyes, nose, ears and mouth closed. Oily water is disgusting to clean out of those places..................
Old 11-05-2011, 11:58 AM
1998Slow 'Stang
All done, it's torqued down to spec on the center pin and the adapter to block. Oil'd and filled with water and no leaks yet. Just need a ride to the autoparts store to get some PS fluid. I had to take the resevoir hose (no pressure) off to get to the clamp for the lower hose. ~$60 and 5 hours total investment. Not too bad if it fixes it.
Old 07-04-2017, 08:02 PM
Thomas J O'Donnell Jr
Thomas J O'Donnell Jr's Avatar
Did it solve your problem
Thomas J O'Donnell Jr is offline
jwog666
12-27-2021 08:09 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
Dathan
10-05-2015 05:52 AM
wraith777
09-28-2015 10:49 AM
belam
Oil and Oil Related Topics
09-23-2015 11:29 PM
Quick Reply: Oil Cooler O-rings
