Smog Pump Removal Question
Old 11-25-2011, 12:02 PM
87 T TOP GT302
87 T TOP GT302's Avatar
Default Smog Pump Removal Question
My smog pump is on it last leg so i'm going to replace it with the smog pump delete kit .My question is what to do about back of heads ?I've still got the tube but how do I block the holes off ?Thanks for looking and responding.
87 T TOP GT302 is offline
Old 11-25-2011, 04:18 PM
primetime5.0
primetime5.0's Avatar
you don't need a delete kit, just run a smaller belt. The back of the heads are threaded however I forget what size it is.
primetime5.0 is offline
Old 11-25-2011, 04:46 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Run a shorter belt
remove tubes from the back of the heads and either pinch and roll them shut, weld them shut, or get the 5/8 plugs
remove the vacuum lines and solenoids from the passenger strut tower
Cap off the vacuum source at the intake
unplug the EGR valve
shove the 2 vacuum lines that go into the fender into them (no need to plug, one goes in and the other is an out so there is no vacuum once you disconnect the one line from the intake)
pinch or weld shut the tube on the midpipe that goes up to the air pump
projectresto83 is offline
Old 11-25-2011, 07:32 PM
Js88lx
Js88lx's Avatar
as far as the lines that go to heads, just cut the hose under the air intake tube and stick a socket in the end and clamp it! works!! same thing for the hpipe! You will use the remaining tube to plug the hpipe and clamp it!!! that way you can convert back to smog without buying a new hpipe!
Js88lx is offline
Old 11-25-2011, 08:21 PM
projectresto83
M.A.D. Motorsports
Works yes....ugly....very much so lol
Who needs smog? open headers FTW!!!!
Old 11-25-2011, 08:59 PM
Js88lx
Js88lx's Avatar
HAHA.., not too ugly, but id rather keep it a little ugly for it being so simple! just add some nice honda stickers not only will it look killer it will add some ponies
Js88lx is offline
Old 11-26-2011, 06:35 AM
projectresto83
M.A.D. Motorsports
http://www.trickflow.com/egnsearch.a...0&autoview=sku
they are 5/8-11 thread. It will most likely be plugged up with carbon so you will have to clean the hell out of it and possible run a thread chaser in to clean it out.
Old 11-28-2011, 08:01 AM
87 T TOP GT302
Thanks for telling me what part I needed .Could you just not put a bolt instead of a plug?
Old 11-28-2011, 08:04 AM
projectresto83
M.A.D. Motorsports
Of course you can
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Smog Pump Removal Question
