331 and 347 questions
Old 12-02-2011, 10:37 PM
86 newbie
86 newbie's Avatar
Default 331 and 347 questions
ok i have a stock 302 block and wanna make a stroker. What is a 347? is it still the 302 block bored to max or is it another block. If its the same block then what makes it the 347 also whats the bore on it and a 331?
86 newbie is offline
Old 12-02-2011, 11:19 PM
tinman
tinman's Avatar
A 347 is a 302 bored .030 over and fitted with a 3.40" stroke crankshaft with the correct pistons and rods.
A 331 is also a 302 bored .030 over and using a 3.25 stroke crank with the correct rods and pistons.
You really can't bore a 302 block past about .060" and have any degree of safety as far is block life goes, even then not all 302 blocks can go that big......
tinman is offline
Old 12-02-2011, 11:35 PM
86 newbie
86 newbie's Avatar
ok thank you that helps a ton! is there a certain brand thats good for the 347 stroker kit?
Old 12-02-2011, 11:37 PM
86 newbie
86 newbie's Avatar
also if you have to bore a 302 block out to a .40 over can u still use the 3.40' crankshaft and still be a 347?
Old 12-03-2011, 04:07 AM
Venomantidote95
Venomantidote95's Avatar
U start spliting hairs then 348 349 lol you still basically have a 347...
Venomantidote95 is offline
Old 12-03-2011, 04:10 AM
Venomantidote95
You have 2 rods to choose from 5.4 or 5.315 that affects piston hiegth and choice.
Old 12-03-2011, 05:07 AM
AdderMk2
AdderMk2's Avatar
have someone build the engine for you.
AdderMk2 is offline
Old 12-03-2011, 02:35 PM
86 newbie
86 newbie's Avatar
thanks guys and adder i want to build it, thats why im asking,i asked because i wanna learn and so forth
Old 12-03-2011, 10:52 PM
tinman
tinman's Avatar
There's a lot of good places to buy the kits from.
One bit of info however, someplaces will tell you it's a balanced kit or they will balance it for $75 or something.
Thats B.S. unless they have the harmonic balncer and the flexplate/flywheel that you're going to be using.
I would aviod the big mail order places like Summit and Jeg's simply because there prices are higher than than some of the smaller places.
I've done a couple engines and I got the rotating assembly from Coast High Performance in California. They have good service and fast shipping. They are part of a company that makes forged pistons so if you want a specail relief or anything like that they are good with it......
tinman is offline
Old 12-04-2011, 07:57 PM
Venomantidote95
There are people here that can help u just ask if everyone paid someone else many of us wouldnt be here on the forums or have the cars we have.... Good luck! As stated dont get the kit prebalanced for many reasons.
Quick Reply: 331 and 347 questions
