Difference between 289 and a 351 windsor
Old 12-14-2011, 02:58 PM
fergal289
fergal289's Avatar
Default Difference between 289 and a 351 windsor
Can anyone give me a simple easy to spot difference between a 289 and a 351 Windsor.
I'm in the UK, and I'm just trying to ID the engine in my 68 Fastback. A picture would be great.
Thanks....
fergal289 is offline
Old 12-14-2011, 05:11 PM
rockinstephen
rockinstephen's Avatar
That's a good question. Sorry, I can't answer it. But while we're on the subject, what's the difference between a 351 Windsor and a 351 Cleveland?
rockinstephen is offline
Old 12-14-2011, 05:13 PM
jesse1125
jesse1125's Avatar
Windsor is a small block, Cleveland is a big block
jesse1125 is offline
Old 12-14-2011, 06:06 PM
JMD
JMD's Avatar
351 - Has about 1" more block above timing cover...
302 - Shorter deck, deck about even with timing cover
These are essentially the same engine design, but the 351 block has about an extra inch or so in cylinder length to accommodate the longer stroke of the 351.
JMD is offline
Old 12-14-2011, 06:07 PM
ponyboychris
ponyboychris's Avatar
At first glance, 289/302's look very similar to the 351 Windsors. The main difference is the 351 Windsors engines are wider at the intake manifold because of the increased deck height of the block (about 1.3" taller). I always determined the difference by looking at the firing order - 289/302W are (1-5-4-2-6-3-7-8) and the 351W is (1-3-7-2-6-5-4-8).
ponyboychris is offline
Old 12-14-2011, 06:22 PM
frdnut
frdnut's Avatar
The easiest way to tell the difference is to look for the two vertical ribs,one on each side of the distributor that run from the intake mounting surface to the timing cover..If it has them it is a 351..Look at the first picture that JMD posted as it shows them very clearly
frdnut is offline
Old 12-14-2011, 07:40 PM
2+2GT
2+2GT's Avatar
The 351C is also a smallblock, of the Cleveland family. Uses the same motor mounts, flywheel, and bellhousing as the 351W, in fact Cleveland heads can be installed on the 289/302/351W with a little customizing. In fact, the 351C 4V heads orignally appeared on the BOSS 302. The overall dimensions of the W and C are nearly identical, and they have the same bore and stroke.
2+2GT is offline
Old 12-14-2011, 11:29 PM
musnicki
musnicki's Avatar
I learn something new every day when I come to this forum. There are some very smart people here.
James
musnicki is offline
Old 12-15-2011, 02:31 PM
fergal289
fergal289's Avatar
Default thanks
Thank you Chaps!
I think you have simplified that for me. Appreciate your input.
Old 12-15-2011, 02:55 PM
JMD
JMD's Avatar
The firing order difference doesn't always work, the later 5.0 HO motors used the 351 order.
289
1-5-4-2-6-3-7-8
302 (Pre-82)
1-5-4-2-6-3-7-8
5.0
1-5-4-2-6-3-7-8
5.0 HO
1-3-7-2-6-5-4-8
5.0 Truck
1-5-4-2-6-3-7-8
351
1-3-7-2-6-5-4-8
JMD is offline
bradleyb
11-27-2015 07:50 PM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Difference between 289 and a 351 windsor
