How to remove strut bar from lower control arm
Old 12-19-2011, 09:16 PM
FoMoJoe
FoMoJoe's Avatar
Default How to remove strut bar from lower control arm
Just ordered all new suspension parts for Christmas. Replacing front end with stock parts. New upper and lower control arms, inner and outter tie rods, shocks and bushings.
Going through the motions and watching some on-line vids.
Looks like the strut rod will have to be removed from the lower control arm, but mine are riveted in vs. bolted. What's the technique for removing these rivets and going to bolts? X pattern with a grinder on top of the rivet then pound them out?
FoMoJoe is offline
Old 12-20-2011, 07:08 AM
LynnBob Mustang
LynnBob Mustang's Avatar
Grind them down and pound them out or use an air chisel and pop the head off then pop it out.
Lynn
LynnBob Mustang is offline
Old 12-20-2011, 01:18 PM
67t5ponycoupe
67t5ponycoupe's Avatar
Riveted, really? I would love to see some pictures. I have done a ton of these front ends and I have yet to see a strut rod riveted to the A arm. Not saying I don't believe you I just want to see.
67t5ponycoupe is offline
Old 12-20-2011, 03:08 PM
jlg2002
jlg2002's Avatar
Or you can drill the rivet heads or upset heads (flattened side) off and then drift punch the remainder out.
jlg2002 is offline
Old 12-21-2011, 02:53 PM
FoMoJoe
FoMoJoe's Avatar
I'm a little lazy to go take a pic right now... but oh, they are riveted on there real good. The upper ball joint is also riveted on there. It's just quicker to replace the whole upper and lower control arms then drill them out and replace it with a bolt on style.
FoMoJoe is offline
GimpyHSHS
09-18-2015 12:27 PM
fastbackford351
09-12-2015 09:42 AM
Dragonus18
09-09-2015 01:21 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: How to remove strut bar from lower control arm
