24 lb injectors on stock 5.0?
Old 12-22-2011, 05:53 AM
Frankenford93
Frankenford93's Avatar
Default 24 lb injectors on stock 5.0?
Would putting 24 lb injectors on my stock 5.0 cause any type of issues I should be aware of? Is there anything else I should change with them?
Frankenford93 is offline
Old 12-22-2011, 06:42 AM
motorman524
MF Informant
motorman524's Avatar
Why do that???
motorman524 is offline
Old 12-22-2011, 11:21 AM
jthorn9
The Godfather
jthorn9's Avatar
Yes the car will not run right as the ECU isn't tuned for 24lb injectors. Stock 19s are good for most head/intake/basic cam setups. To run 24s you either need an MAF programmed for such (good option), Cobra ECU (better option), or your ecu tuned/tweeked on a dyno tune (best option)
jthorn9 is offline
Old 12-22-2011, 03:53 PM
Frankenford93
o.k. Thanks!
Old 12-24-2011, 07:13 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
...don't do it....
my rule of thumb for a NA setup....if you don't run aluminum heads you don't need them..
projectresto83 is offline
Old 12-24-2011, 08:50 AM
ttocs
ttocs's Avatar
why does it matter if they are Al?
I upgraded mine when I did new heads/cam this summer. Then on the dyno it showed that the fuel pump was not keeping up with them. Until you get into the motor and start modding it the 19s are fine and there would be no perfomance gain with upgrading it until then.
ttocs is offline
Old 12-24-2011, 08:56 AM
projectresto83
M.A.D. Motorsports
I say aluminum because thats when people start getting into the power levels that need 24lb injectors. There are only a couple cheap aluminum heads that don't need them.... GT40's really don't need them unless they are heavily ported...iron Dart or windsor jr/sr heads I would use 24s with but very few run those.
Old 12-24-2011, 09:31 AM
nitrous_bob
nitrous_bob's Avatar
yeah as long as its all working fine, stock everything will support 300hp no problem
nitrous_bob is offline
Old 12-24-2011, 10:07 AM
ttocs
ttocs's Avatar
ok I gotcha then. I though you were trying to say just the material dictated their use but this makes better sence.
300 always seemed high on the stockers to me. I could only imagine that at that point the inectors would be choking the motor but then I am not the motor expert.
ttocs is offline
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
JT76
09-20-2015 11:32 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: 24 lb injectors on stock 5.0?
