2004 mach 460 replacement door speakers
well took off door panel today and thought my speaker was just rattling and nope found out its blown. Its not always bad just when i turn it up the base makes them rattle or sound like ****. I only have the base set in the middle its not even way up. My system is stock 460 so was wondering if i should just throw a factory replacemnt on back in or what a good replacement would be and just yank the two front ones and throw some new better ones in?
Thanks
Thanks
never found a good replacement for it because it is an 8 ohm 5 x 7 woofer. Closest I think I ever heard was a dual 4 ohm 6.5 version that could fit but its been a while. If you have replaced the deck, you can bypass the stock amps and just put a fullrange speaker there and run it off the deck power no problem.
Samething happened to me. Went with Alpine Type-R to keep up with wattage (around 100watts/rms). Year later ended up gutting the entire sound system. Just a heads up, you will LOSE a lot of low end sound, but gain mid-range detail... It's a 'some hate it or some love it' scenario
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
