My Recession Buster Engine Build
Old 01-12-2012, 04:17 PM
Bpohlman13
Bpohlman13's Avatar
Its lookin nice! Dont forget, your front end of your car is going to rise slightly do to the lighter engine. What are you setting your car up for? Drag racing? Twisties?
What are you going to do as far as exhaust? Lts?
Keep us updated!
Bpohlman13 is offline
Old 01-12-2012, 04:46 PM
school boy
school boy's Avatar
yea, this would be like throwing flat tops in your current motor. you do need a stae 3 cam or bigger because of the compression. guys, read the thread i posted in the op.
yea the car is setup for twisties. there will be updates later tonight, with pics!
school boy is offline
Old 01-12-2012, 06:20 PM
smitty2919
smitty2919's Avatar
Originally Posted by Jay-rod427
Didn't Mark 8's have the the TB at the back of the engine? Also why did you buy a 4V complete engine just to put 2V PI heads on it, or am I missing something?
93-95 had the throttle body at the back, 96-98 got a revised intake manifold like the one you see in the pics.
smitty2919 is offline
Old 01-12-2012, 06:45 PM
JC316
JC316's Avatar
Incorrect. The 93-96 had the old style intake, the 96 got the "Intech" badging, but nothing else; the 97-98 had the new style intake.
JC316 is offline
Old 01-12-2012, 07:07 PM
Jay-rod427
Jay-rod427's Avatar
Good things to know. Thanks guys.
Jay-rod427 is offline
Old 01-12-2012, 10:15 PM
school boy
school boy's Avatar
update:
so i can run my cams at 108 centerline without ptv contact, i done this:
i took a intake valve im not using and grind flats on the upper part of the stem
i used a hex quickdisconnect collor to drive the valve
i then cut out 80 grit sand paper with the sticky on the back side and attached it to the valve
i then installed the valve in a spare bare head, put the head onthe engine with the locating dails and put the quick disconnect on the valve. i used drill to spin the valve to make my own valve reliefs.
i repeated the process for each cylinder. i cut the reliefs .050-.058 deep
Old 01-12-2012, 11:29 PM
Bpohlman13
Bpohlman13's Avatar
Nice! for each piston you did, did you bring it upto tdc first? Because if not, they will be off and wont do anything.
Old 01-12-2012, 11:34 PM
school boy
school boy's Avatar
yea, every piston was brought up to tdc
Old 01-13-2012, 05:58 AM
  #19
uberstang1
Chupacabra
uberstang1's Avatar
Originally Posted by dwtjr3
So i could get a mark 8 motor and throw 2v heads on it and everything else will be the same as stock then? all the connections and everything?
This would be a very bad idea with boost, the stock shortblock wont handle it with a compression that high.
uberstang1 is offline
Old 01-13-2012, 09:51 AM
  #20
dwtjr3
dwtjr3's Avatar
Yeah 11-1 is high for boost. I just didnt know that the CR would be that high just by putting a 4v short block in
dwtjr3 is offline
Quick Reply: My Recession Buster Engine Build
