AIR BAG LIGHT FLASHES 5 TIMES...???
Old 01-15-2012, 08:45 PM
OiDALE
OiDALE's Avatar
Default AIR BAG LIGHT FLASHES 5 TIMES...???
Ok, this is driving crazy, a couple of weeks ago my air bag light came on in 5 flash burst with a couple seconds between...It flashes 5 times and keeps cycling over and over again while the car is on. Its a 1991 GT. It just appeared one day after the car sat for a couple of days. Its a garage kept car so no outside elements.
But about 4 days ago the light went out and a beep from under the das replaced it with the same sequence. A couple of days ago the tone was replaced by a broken tone like a crackle, seemed like it was breaking up (loose wire)...Today I went underneath the dash and found a little whit box where the tone came from. I moved it around, unplugged it and plugged it back and the tone stopped.
Now the light is back...Please help me out??? Its a 5 flash sequence which goes on and on...
OiDALE is offline
Old 01-15-2012, 09:50 PM
ttocs
ttocs's Avatar
the beep means you have a warning light that is out, I would guess that being the airbag.
ttocs is offline
Old 01-16-2012, 09:56 AM
OiDALE
OiDALE's Avatar
The beep went away and the light flashing 5 times over and over again is back...
OiDALE is offline
Old 01-16-2012, 01:30 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
cheap: put tape over the light if you dont want to fix it...
proper: fix the problem correctly
rmodel65 is offline
Old 01-16-2012, 02:33 PM
mattdel
mattdel's Avatar
The 5 beeps is the systems malfunction warning system. It's telling you that the airbag module has an internal fault, and will need a proper diag and likely expensive fix. Taking the module out(that white box you found) will solve the beep and the light, but you will have no airbag deployment, should you ever need it.
mattdel is offline
Old 01-16-2012, 05:51 PM
Bubba 95SN
Bubba 95SN's Avatar
veryuseful.com has airbag tests.
Bubba 95SN is offline
Old 03-29-2012, 08:15 PM
mustang1952
mustang1952's Avatar
I have the same problem now with my 1992 GT.
Where is this white box at?
mustang1952 is offline
Old 03-29-2012, 08:50 PM
Tony71502
Tony71502's Avatar
Glove compartment. It's a blue box.
Tony71502 is offline
Old 03-29-2012, 10:25 PM
frost1357
frost1357's Avatar
I have the same issue. I've been told its the clock spring in the steering wheel. My light and beeping noise start and my steering wheel controls stopped working. no horn or cruise control
frost1357 is offline
Nick Oliver
10-17-2018 04:22 AM
MusicCity615
09-12-2015 07:05 AM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
zachary1988
09-04-2015 03:04 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: AIR BAG LIGHT FLASHES 5 TIMES...???
