Heater Hose Assembly or Heater Return Line?
Old 02-17-2012, 06:46 PM
dswa85
dswa85's Avatar
Default Heater Hose Assembly or Heater Return Line?
2001 Ford Mustang GT (4.6L, V8) Single Cam.
Hose coming out of the firewall and into the ??engine, radiator, or somewhere? *thinking it may be the heater return line*, started leaking last night. When investigating the nipple coming off the engine, radiator, or somewhere, broke!!! Is there a replacement?
I appreciate any and all thoughts, ideas, opinions, whatever...
Thank you,
Daniel
DSWA85@Gmail.com
dswa85 is offline
Old 02-20-2012, 09:18 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
You will need to replace the intake manifold, get the FRPP replacement. Stay away from the Dorman unit sold by the FLAPS.
BTW, that is the heater core inlet...
cliffyk is offline
Old 06-13-2013, 03:08 PM
blu30val
blu30val's Avatar
I haven't searched too much on the forum but I'm having an issue finding the hose thats missing from this pic. Local parts houses just have molded hoses, Nothing with the plastic couplers.
blu30val is offline
Old 06-13-2013, 06:41 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It's an adapter sort of thing, separate from the hose--Motorcraft # KT83; Rockauto has them for $14.11...
cliffyk is offline
Old 06-13-2013, 08:57 PM
blu30val
blu30val's Avatar
Sweet, thanks cliff. By the way that's the outlet right?
blu30val is offline
Old 06-13-2013, 09:08 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The hose from the intake manifold nipple to the heater core is the inlet, the outlet is the pipe that runs through the valley under the intake manifold and to the rear of the water pump housing:
cliffyk is offline
Old 06-16-2013, 01:31 PM
blu30val
blu30val's Avatar
Thanks again.
blu30val is offline
Old 03-18-2017, 09:28 PM
Jonez101
Jonez101's Avatar
Default Anyone know what this is
Jonez101 is offline
Old 03-18-2017, 09:58 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Originally Posted by Jonez101
That's the coolant return line for the heater core...
cliffyk is offline
Old 03-18-2017, 10:05 PM
Jonez101
Jonez101's Avatar
Where could I order that elbow
Jonez101 is offline
Quick Reply: Heater Hose Assembly or Heater Return Line?
