electrical or fuel puzzle 428 super cobra jet
Old 02-22-2012, 06:18 AM
coach
coach's Avatar
Default electric/fuel 428 cobra jet
Originally Posted by 67 evil eleanor
When you turn off the key and it keeps running, how do you stop it? Also having a EB carb gives a hint that the engine may have a lot of compression, this could explain the diesel effect. I would suggest some high octane fuel if this continues, the tank will need draining.
Well, it appears to be a combination of both, I put some dry gas in the tank for the existing tank (a little less than 1/2), pulled the distributor cap and checked the dwell, filed the points and reset them, found some moisture on the inside of the cap and adjusted the idle on the edlebrock carb and put new high test gas in the car and it ran a whole lot better. But think I am going to put new points, filing them down is only a quick fix and temporary.
Again, thanks everyone for your imput
Coach
coach is offline
Old 02-22-2012, 07:05 AM
67 evil eleanor
67 evil eleanor's Avatar
Mositure, ouch. Your on the right track. Maybe time for some "Seafoam" also.
67 evil eleanor is offline
11-10-2015 11:39 AM
uberstang1
09-20-2015 06:42 PM
TfcCDR
09-14-2015 12:08 PM
fastbackford351
09-12-2015 09:42 AM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: electrical or fuel puzzle 428 super cobra jet
