F14 Sizing
Old 03-09-2012, 04:18 PM
  #21
Paul@HoweyIndustries.com
Former Sponsor
Paul@HoweyIndustries.com's Avatar
Originally Posted by wantgt
Didn't get one.
That's odd... I guess it didn't send. I sent you another one.
-Paul
Paul@HoweyIndustries.com is offline
Old 03-10-2012, 02:29 AM
  #22
Dacam
Dacam's Avatar
Originally Posted by Paul@HoweyIndustries.com
Did you place the order with us? If so, please send me a PM with your name so I can look up your offsets to make a lowering recommendation. If not, can you please tell me what offsets you ordered?
If the Toyo's are in the budget, yankeehick5.0 is 100% correct on his recommendation. Brands like Continental and Michelin have notoriously high side-wall compared to other brands. I would stay away from those on a 20" wheel setup with suspension mods.
-Paul
Paul,
So your saying that not all tires that have the same series ie35 or 30) are the same? Michelin 295/30/20 will have a taller sidewall then another brand's 295/30/20?
Dacam is offline
Old 03-10-2012, 10:47 AM
  #23
Former Sponsor
Originally Posted by Dacam
Paul,
Correct, we have found the both Michelin and Continental both have a larger side wall then other brands with the same profile. We found this to be true when we have had to do fitment on vehicles where every MM of space was needed to make the setup fit without rubbing.
When we encounter "extremely aggressive" fitment like that, we generally go with the Toyo's if we need a nice tire with a small profile for fitment that has tight tolerances. Hankook is another good brand that keeps a nice low profile.
Old 03-10-2012, 05:03 PM
  #24
stang8psi
stang8psi's Avatar
really cause every single tire in a 295/30/20 is 27" Even Pirelli, Michellin,and goodyear,continental They are all the same 27" overall diameter!
stang8psi is offline
Old 03-10-2012, 07:56 PM
  #25
Former Sponsor
Correct, these are the ratings but the fitment doesn't lie. These are our findings over years of test fitting a variety of vehicles with extremely aggressive setups.
For example we did a test fitment on a G37 with a very aggressive 20x10.5 wheel in the rear and a slammed suspension setup. The Continental rubbed and the Toyo's did not. Same exact tire sizes, different results.
Again, this will only be an issue in extreme cases where we need to take advantage of every MM of available space. We are also talking MM differences on the tires, not inches.
Quick Example: Yokohama 305/30/19 = 26.1 Diameter / Toyo Proxes = 305/30/19 = 26.3 Diameter
I know we are talking very little differences that will not really apply to most Mustang owners. But when you are fitting cars like we are, every little bit counts.
Old 03-20-2012, 01:09 AM
  #26
MustangCHN
MustangCHN's Avatar
F14 really looks so awesome. the best part is that u got a lot of choice of offset
MustangCHN is offline
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
10-01-2015 09:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
09-29-2015 03:23 PM
Quick Reply: F14 Sizing
