no air will blow for ac or for heat
Old 02-27-2012, 02:44 PM
cory21
cory21's Avatar
Default no air will blow for ac or for heat
i have a 2005 mustang gt and recently when i turn on the fan either for heat or for a/c no air will come through the vents... the fan and everything seems to switch on as it should but it has no real power.. it doesnt matter whether the fan switch is on 1 or 4 its as if the air is just floating through the vents and not really coming out with any real force..
cory21 is offline
Old 02-27-2012, 04:49 PM
DPHC13
DPHC13's Avatar
sounds silly but did you check the fuse? Next problem is if the fuse did blow... why? Check um out. Have you had the dash apart lately?
DPHC13 is offline
Old 03-09-2012, 10:19 PM
cory21
cory21's Avatar
sorry for the delay.... but yes i have checked ever fuse and they all are good. Is it at all possible that the simple switch control is bad for the power? maybe it was in the 1 position and the switch went bad and now its stuck there?
cory21 is offline
Old 03-10-2012, 08:00 AM
Nuke
Nuke's Avatar
I haven't the foggiest but here's the link for the shop manual. Just dig down to the section for the HVAC.
http://iihs.net/fsm/?dir=1
Nuke is offline
Old 03-10-2012, 09:12 AM
157dB
Cut & Paste Expert
157dB's Avatar
Check your blower resistor first.
http://iihs.net/fsm/?dir=40&viewfile...l%20System.pdf
The blower resistor has a fuseable link in it.
Its located on the plenum under the dash below the glove box.
It has an electrical connector going to it and is held in with
two or three screws, Easy removal and most posably the problem.
Its in the center of the pic below.
The electrical connector is mostly shown.
This controls low medium and high speeds and is cooled by the airflow
in the plenum.
157dB is offline
Old 03-10-2012, 03:12 PM
Nuke
Nuke's Avatar
157db, if I didn't know better, you have that shop manual memorized. Thanks for zeroing in for the OP.
Nuke is offline
Old 03-11-2012, 12:13 PM
SpartaPerformance
SpartaPerformance's Avatar
Sounds like you need a blower motor resistor
SpartaPerformance is offline
Old 03-11-2012, 01:17 PM
ironh19
ironh19's Avatar
might be out of blower fluid
ironh19 is offline
Old 03-12-2012, 03:38 PM
cory21
cory21's Avatar
its weird because everywhere i read it says that if the blower resistor is bad it only blows on high speed.. mine blows air on whatever speed i turn the dial too its just weak, seems more like speed 1 than speed 4... but ill give it a shot, looks easy enough
cory21 is offline
Old 03-12-2012, 04:00 PM
Young_Gun
Young_Gun's Avatar
First time I took the dash apart I forgot to reconnect the harnesses.
Young_Gun is offline
Quick Reply: no air will blow for ac or for heat
