Arrow in or arrow out on GT500 strut mounts?
Old 03-03-2012, 05:34 PM
mayo
mayo's Avatar
Originally Posted by 157dB
well bro its rollin, so I guess not
besides i like to live DANGEROUS!!!lol
mayo is offline
Old 03-07-2012, 08:26 AM
mayo
mayo's Avatar
Alrighty, just got back from the shop with the alignment spec's...
Setup:
FRPP P springs
Koni STR.T shocks/struts
GT500 strut mounts...arrows pointed toward engine.
BEFORE
AFTER
Toe as stated by original member seemed to be effected, but an easy adjustment. All in spec, no unwanted noises from setup...mayo is a happy camper and V is one sexy bitch
mayo is offline
Old 03-07-2012, 10:20 AM
HxCGuitars
HxCGuitars's Avatar
Dang! That's awesome Mayo! Congrats on the camber man haha.
HxCGuitars is offline
Old 03-07-2012, 11:01 AM
mayo
mayo's Avatar
Originally Posted by HxCGuitars
Dang that looks good
I'm interested to see how much it will help my car when I FINALLY lower it.
Thanks bro...
Now here's the thing, and I'm just speculating here so don't quote me. This setup will probably work if you stay with the P springs, maybe even with the steeda springs as its only 1" of drop in the front.
Travel outside of those setups, like the K springs with 1.5" of drop and your camber will require adjustment I would think, like jeff.
Something to keep in mind.
mayo is offline
Old 03-07-2012, 03:04 PM
J2L06GT
J2L06GT's Avatar
Mayo, glad you did this and posted specs sheets.
When I originally did this, didn't have a printout to post.
My springs are H&R Sports w/1" drop also.
I've got over 30k miles like this now with no problems.
The only reason the install instructions tell them to point
arrow out is with stock spings thats factory setup.
With arrow in and lowered there is actually less stress on
upper mount because its twisting it a smaller angle.
J2L06GT is offline
Old 03-07-2012, 03:18 PM
mayo
mayo's Avatar
MY HERO ARRIVES!!!lol
Dude thanks so much for the info that you posted, saved me some coin. Without your idea I would have probably purchased camber plates to finish the job. That being said I might use some of the extra $$ for some fog lights like your's, i'm diggin that setup you got goin bro...looks clean!
Thanks again, first round is on me
mayo is offline
Old 08-30-2013, 02:23 AM
Sethman29
Sethman29's Avatar
Sub'd! Thank you all
Sethman29 is offline
Old 08-30-2013, 07:53 AM
hootie_john
hootie_john's Avatar
I'll be doing my SR springs (1.5" drop) from AM with GT500 mounts in the morning. At my last tire rotation at the stealership, I was already -1* or so on the front from the factory with the 18" factory bullets. At 20K miles, I was noticing some slight inner tire wear. Nothing serious, but a hint was there for sure. I'm planning on turning the mounts "in" when I do the install to hopefully stay somewhat within spec. I think up to -1.5* is still considered within spec, but don't quote me on that. If nothing else, I'll just have to stay on top of tire rotations.
hootie_john is offline
Old 08-31-2013, 10:29 AM
  #19
157dB
Cut & Paste Expert
157dB's Avatar
http://iihs.net/fsm/?dir=60&viewfile...20Assembly.pdf
Align the notch on the upper bearing assembly
with the clevis at the bottom of the strut.
157dB is offline
Old 09-01-2013, 12:36 PM
  #20
hootie_john
Got the springs in and the GT500 mounts. Turned the notch "in" on the mounts. Ill drive it for a while and let things settle before I check alignment. I'm hoping they settle some because it looks to have only dropped an inch at this point.
Quick Reply: Arrow in or arrow out on GT500 strut mounts?
