89 Gt Running really rich. Thoughts?
Old 03-02-2012, 01:26 AM
116Clique
116Clique's Avatar
Default 89 Gt Running really rich. Thoughts?
ok, i have my 89 Gt and it is running very rich. Mod that maybe the culprit is the long tube headers. I am pulling code 44 and 94 related to the O2 sensors. What are my options to getting the car the run correctly. I can smell fumes sometimes as i'm driving and MPG is worse than expected for the few mods on it so far. Any other threads i can check out or advise would be great.
thanks.
116Clique is offline
Old 03-02-2012, 10:04 AM
Five0hFox
Five0hFox's Avatar
My car was running so rich that's was smoking black. Turned out to be a stuck injector.
Five0hFox is offline
Old 03-02-2012, 10:32 AM
mattdel
mattdel's Avatar
Try this:
https://mustangforums.com/forum/5-0l...l.html#2355308
mattdel is offline
Old 03-02-2012, 02:08 PM
116Clique
116Clique's Avatar
Mattdel,
So you think that it could be the ECT Sensor and not the O2 sensors misreading the cylinders?
Old 03-02-2012, 02:11 PM
mustangGT86_05
mustangGT86_05's Avatar
O2 sensors will throw codes for detecting an excessively lean or rich condition, not just because they are faulty. Also, the only way the headers would cause it is if they were not sealed properly, the o2 sensors would see added air and throw more fuel to compensate. So my question would be is your o2 sensor code saying lean, rich, or a circuit failure?
mustangGT86_05 is offline
Old 03-02-2012, 02:36 PM
mattdel
mattdel's Avatar
44 and 94 together usually mean that the entire system is leaned out. Seeing them together almost surely eliminates them as the cause. Lots of reasons for these codes to pop up.
ECT
Fuel pump
Clogged injectors/fuel filter
Intake leak (tube/gaskets)
Exhaust leak (before the o2's)
Each time we see these codes, it ends up being something different, but its not the oxygen sensors.
mattdel is offline
Old 03-02-2012, 04:23 PM
116Clique
116Clique's Avatar
ECT
Fuel pump
ECT- Plan to check this just as your other thread said to. need to get a new multimeter. perhaps ill just pick a new ECT.
Fuel pump- Planning to order a new one very soon(Any considerations for a very mildly modded mustang?) my sending unit is also making the fuel guage display incorrectly.
Clogged injectors/fuel filter- ill have to work on this one
Intake leak (tube/gaskets)- truthfully not sure
Exhaust leak (before the o2's)-hearing a small leak on the pass side in the vicinity of headers/heads link.
My car is also having a hard time starting: the voltage reads normal while running, but prior to start while on ACC. the voltage reads in the red. all this to say its a great time to ride the CBR and work on the car. all help is much appreciated.
bjdutch2005
03-24-2017 03:38 AM
2007StangV6
01-28-2016 06:09 PM
Pyrate Dave
09-10-2015 07:30 PM
zachary1988
09-04-2015 03:04 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: 89 Gt Running really rich. Thoughts?
