boss 347
Old 03-06-2012, 12:52 PM
YELLOWRIDE91
YELLOWRIDE91's Avatar
Default boss 347
Has anybody here ever used dss racing before. I would like some feed back on my build from them. boss 347 any help is appreciated
YELLOWRIDE91 is offline
Old 03-06-2012, 01:05 PM
YELLOWRIDE91
it my first day in here i'm a virgin to this site. Has anybody here ever used dss racing before. I would like some feed back on my build from them. boss 347 any help is appreciated.
Old 03-06-2012, 11:21 PM
tinman
tinman's Avatar
Building a 347 out of using the Ford 'BOSS' block isn't really a good idea if you are thinking of using a 3.400 stroke crank.
For some reason Ford made the cylinder walls on the new blocks very short towards the bottom, this causes the piston to travel to far out of the cylinder when used with a 3.400 stroke crank.
Better shops won't even build one the way.
However, you could make a 347 by doing a 331 and overboring it to make a 347.
Cgheck but I rthink it's something like 3.250 stroke and then 4.125 bore to get to 347, that may work out for you......
Also try CHP.com for good quality engine parts..........
tinman is offline
Old 03-07-2012, 01:55 PM
YELLOWRIDE91
Default boss 302 oil pick up.
will the oil pick tube work out of the stock 302 base engine. If not can some one tell me can i modify the one have to work. or do i need to buy one.
Old 03-07-2012, 01:56 PM
YELLOWRIDE91
sorry i have a boss block will the 302 stock one work.
Old 03-07-2012, 06:12 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
i don't believe the stock will work due to the main cap orientation
mjr46 is offline
Old 03-07-2012, 07:40 PM
YELLOWRIDE91
Thanks. I heard u mite be able to modify it. Though I would ask.
Old 03-08-2012, 12:53 AM
tinman
tinman's Avatar
I'm thinking someplace like Canton will sell you a new pick-up tube.
Maybe Ford Racing?
tinman is offline
Old 03-08-2012, 05:55 AM
mjr46
mjr46's Avatar
why would you want to try to run a stock pick up?? you can't use a stock pan either iirc due to main caps but I could be wrong
mjr46 is offline
Old 03-08-2012, 07:21 AM
YELLOWRIDE91
OK thanks thats what i needed to know.. i wasn't going to use the stock pan .. ethier canton or dss.
Quick Reply: boss 347
