Traction issues on my newest pony
Old 03-18-2012, 12:13 AM
  #21
ym42
ym42's Avatar
Yes, double checked on highway today, warm weather warm tires. Got General Exclaim UHP, they stick to a smooth highway like a glue, whole front jerks up when I power shift from 1st to 2nd no wheel-spin. Now I don't worry about tires, hope the frame and clutch/mounts hold up lol:-)
ym42 is offline
Old 03-18-2012, 12:46 AM
  #22
Shift
Shift's Avatar
Originally Posted by thestable
Thanks for the replies fellas! So tires and control arms.. What is the biggest tire that you can fit on the Bullitt 17x8? I was hearing great things about the Nitto drag radials, but would I need a bigger rim to fit 275/40/17's? Also which CA's work best on these bodies?
Nitto's are awesome tires! And everyone here talking about LCAs are right in that they'll help. I have a set of Nitto NT555 tires on my Roush 18x10 wheels. Dry performance they are amazing; they are pretty good in wet, BUT pretty bad in snow/ice (Obviously cause they are summer high performance). They also look very beefy and the tread looks good. Here's a pic to help iterate all of what I said.
Shift is offline
Old 03-18-2012, 11:33 AM
  #23
ski
ski's Avatar
Cold ambient temps, improper tire pressure, winter road grit, and aftermarket gears(3.73's/4.10's) will cause major tire slippage.
My GT has replacement Pirelli's the same size as the stock OEM's and 3.55's, and the only time it gets squirrely during a 1-2 shift is if the road is either wet or coated with grit, or the ambient temps are cold(30's or below).
ski is offline
Old 03-24-2012, 04:57 PM
  #24
aiminglow
aiminglow's Avatar
My setup gets traction like crazy. As in even when it's cold, I'm lucky if I chirp the tires going into 2nd gear, and the thing launches very well, and is straight as an arrow. Also keep in mind, I have around 400hp at the crank.
Suspension mods are: Strut tower brace and a-arm brace (don't let the 'experts' on forums tell you those do nothing. Anything to help transfer power to the wheels rather than twisting the chassis helps you go faster, and allows for straighter launches. Plus I've experienced their benefits first hand), lca's, uca (also helps with keeping straight), and a swarr bar (aka rear axle brace.) I'm running sumitomo stock size tires, 235/55 r17.
As far as wider tires, they can help to a certain degree, but what's a lot more important is the tire compound. I prefer running something that I can still drive when it rains (wide tires aren't good in those conditions), and the softer compound the sumitomo's have really helps. I will say that a very high percentage of my traction overall comes from the tires, but it's the rest of the suspension that works hand in hand, and keeps the car going straight.
aiminglow is offline
Old 03-24-2012, 07:03 PM
  #25
moosestang
moosestang's Avatar
You don't need wide tires, what you need is high performance tires, instead of those all season spin machines. I'm still using 235/55/17's and manage just fine.
moosestang is offline
Old 03-24-2012, 09:51 PM
  #26
Young_Gun
Young_Gun's Avatar
I run Firestone Firehawk Wide Oval Indy 500 tires and I'm loving them. Good grip - but not too much.
Young_Gun is offline
tmdm
09-18-2015 03:10 PM
LivingInThePast
09-16-2015 12:20 PM
Mustangmalo
09-14-2015 06:23 AM
tj@steeda
Steeda Autosports
09-08-2015 11:50 AM
iculookin
09-02-2015 12:34 PM
Quick Reply: Traction issues on my newest pony
