which direction should electric fans blow?
Old 03-17-2012, 01:48 PM
marlyman
marlyman's Avatar
Default which direction should electric fans blow?
title says it all - a buddy of mine told me that electric fans are supposed to blow into the radiator..when i wired them at first i put + to + an - to - and that made the fans blow towards the motor...now my friend told me to switch + to - an - to + so that the fans like cool the radiator fluid instead of the motor itself... kinda makes sense whats the final verdict tho?
marlyman is offline
Old 03-17-2012, 02:10 PM
mustangGT86_05
mustangGT86_05's Avatar
if your fan is on the engine side of the radiator, you want it to pull air through the radiator (air going to the motor). If its on the opposing side you want it to push through the radiator. Make sure you have your blade on correctly too, if it isn't you may not get proper cooling.
mustangGT86_05 is offline
Old 03-17-2012, 03:25 PM
AdderMk2
AdderMk2's Avatar
hey should be mounted on the engine side, and draw air THROUGH the radiator
AdderMk2 is offline
Old 03-17-2012, 04:48 PM
DRAGUL
DRAGUL's Avatar
Think of it this way, which way does the air blow into the radiator when you drive down the road
DRAGUL is offline
Old 03-19-2012, 07:29 AM
Tony71502
Tony71502's Avatar
Still,
Fan should be on engine side or you are hurting cooling performance. I don't care how amazing your fan is, if you are covering part of the radiator with a shroud before the fan can even touch the air, you are hurting yourself.
Tony71502 is offline
Old 03-20-2012, 07:45 PM
DRAGUL
DRAGUL's Avatar
Originally Posted by Tony71502
Still,
I think it is mounted on the engine side. He was reversing polarity to get it to run in the oposite direction. Blowing to the front. Hell I could be reading it wrong.
DRAGUL is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Sixer4Life
09-29-2015 07:03 PM
Quick Reply: which direction should electric fans blow?
