Fuel cap venting
Old 03-28-2012, 03:30 PM
jt1991
jt1991's Avatar
Unhappy Fuel cap venting
I just replaced the fuel pump in my 86 mustang GT and now it's doing something strange that it didn't do before. I runs fine, no strange noises, etc, but when I take the gas cap off right after running it (especially if I've had the A/C on), there is a very strong hissing noise and the strong smell of gas. When it does it's hissing sound, I don't know if it's sucking air in or expelling air. What's up with this??? Is it dangerous????
Jeff
jt1991 is offline
Old 03-28-2012, 03:37 PM
mattdel
mattdel's Avatar
Vapor lock inside the tank. Vent tube on the top of the tank is clogged/pinched/melted.
mattdel is offline
Old 03-28-2012, 04:34 PM
mustangGT86_05
mustangGT86_05's Avatar
True that older cars like ours run vented, but newer cars are sealed and do this normally thanks to emissions regulations. However since your system isn't designed to do this, there are risks, make sure it isn't collapsing your tank
mustangGT86_05 is offline
Old 03-28-2012, 07:52 PM
Bubba 95SN
Bubba 95SN's Avatar
HISSSSS.......Cobra in the tank!
Bubba 95SN is offline
Old 03-29-2012, 09:07 AM
jt1991
jt1991's Avatar
How do I test to see if the vent tube is bad without dropping the gas tank again?
If the problem is a vapor lock, how do I fix that?
Or is fixing either problem involve dropping the tank and replacing the vent tube?
jt1991 is offline
Old 03-29-2012, 09:52 AM
jt1991
jt1991's Avatar
What would happen if I took the vent tube from the tank that runs to the charcoal canister and instead of running it to the canister, splice it directly into the line that runs to the PCV valve (which is where the trapped vapors in the charcoal canister go anyway?
jt1991 is offline
Old 03-29-2012, 10:16 AM
Tony71502
Tony71502's Avatar
The charcoal canister vapors go into the intake manifold and go into the airstream to be burned like normal fuel. They do not and should not go into the crankcase.
Tony71502 is offline
Old 03-29-2012, 11:52 AM
capri debris
capri debris's Avatar
If it wasn't doing this before you dropped the tank to replace the fuel pump, I'd be willing to bet you pinched the vent hose somewhere above the tank when reinstalling the tank... so simply bypassing the charcoal cannister and running the hose directly to the intake won't solve your problem since the cannister, more than likely, isn't your problem either.
I'd unhook the vent hose at the cannister and put a vacuum gauge on it to see of it holds vacuum... if it does, you have it pinched above the tank. It should flow freely and NOT hold vacuum... if it's flowing fine, THEN you have a cannister problem... and actually, it probably isn't the cannister, it's probably the solenoids that open and close the flow from the cannister to the intake. They are either not working or not getting a signal from the ECU, or you have a clog somewhere in that general area.
But once again, I'm going with YOU caused this problem by pinching the vent hose since this problem presented itself only after you dropped the tank...and now you're faced with dropping the tank again and correcting the issue.
capri debris is offline
Old 03-29-2012, 10:47 PM
jt1991
jt1991's Avatar
Talking Fuel cap venting noise
Thanks to all who answered my question!!!
I inspected the area by the gas tank and SURE ENOUGH!!! I pinched the vent line above the gas tank against the car body. I dropped the tank about 1 inch, moved the hose out of the way and that fixed the problem!!! The whole thing took about 1 hour.
Jeff
jt1991
jt1991 is offline
Old 06-16-2013, 07:12 PM
mstahoo
mstahoo's Avatar
Couldn't one just get a vented gas cap and call it a day? .. ....serious though.. :/
mstahoo is offline
Quick Reply: Fuel cap venting
