Power source for aftermarket heated seats
Old 03-29-2012, 08:23 AM
Marky82
Marky82's Avatar
Default Power source for aftermarket heated seats
I finally bought 2 sets of these aftermarket heated seats and now I have to install them. The instructions say I need to find a 12v ignition source driving up to 10amp continuous current per seat. The heaters have a power consumption of about 70 watts per seat.
Are there two open spots in fuse box (the one near the pass. side kick panel) where I can use those add-a-fuse taps? I would need one 10amp tap for each seat.
Do these draw too much power to just tap a fuse? Should I run a wire directly from the battery and wire a relay?
Any advice/recommendations are greatly appreciated!
Thanks,
Mark
Marky82 is offline
Old 03-29-2012, 08:48 AM
Antonio323
Antonio323's Avatar
I have heated seats on mine, but I have yet to install them. What a coincidence that I saw this thread just as I was doing some research. But anyway, according to the owner's manual, fuses 42 and 44 draw 10 amps each and they are free fuses, as in they are NOT powering any accessory. You should be able to use those two. I'll probably start mine later today, I'm about to end my overnight shift at work and I'm gonna go home and crash for a while.
EDIT: Just noticed you have an '07. Mine's a 2010, so it may be possible that the fuses I mentioned apply only to mine. You should consult the owner's manual to verify.
Antonio323 is offline
Old 03-29-2012, 11:25 AM
bones302
bones302's Avatar
This may go without saying, but my advice is to make sure the power sources are only on with the ignition (unless the seats have a timer auto-off capability). but even so, you don;t want to leave the seats on by accident after you shut off the car.
bones302 is offline
Old 03-30-2012, 03:29 PM
White05GT
White05GT's Avatar
Fuse 12 or 13 is the one I used on my 05 and sis's 07 to power the seat heaters. Only works with the key on. Wired the power to both seats to one add-a-fuse tap like you have pictured.
Your owners manual will tell you for sure which fuse it is, is listed as unused.
Edit: just checked, it's #13. You'll love having them!
White05GT is offline
Old 03-30-2012, 03:54 PM
Marky82
Marky82's Avatar
Are you worried about both seats drawing too much power from that one fuse? I can only find 10amp add-a-fuse kits and my heated seat instructions says each seat requires 10amps.
Marky82 is offline
Old 03-30-2012, 04:28 PM
Nuke
Nuke's Avatar
Here's how it's fed with the OE heaters:
http://iihs.net/fsm/?dir=40&viewfile...lled Seats.pdf
Nuke is offline
Old 03-30-2012, 04:59 PM
Antonio323
Antonio323's Avatar
Sorry OP, don't mean to thread jack. I have run both harnesses under the carpet and onto the front on both driver and passenger heated seats. The passenger harness is right next to the fuse panel, but the driver harness isn't near any fuse. How would I go about wiring the driver harness?
Old 03-31-2012, 02:43 PM
White05GT
White05GT's Avatar
Not worried at all, both seats also have a 10 amp inline fuse in the kit I used. Sis has had hers in over a year, mine since december. No probs at all.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
BOBCATJACK
09-14-2015 02:18 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
Quick Reply: Power source for aftermarket heated seats
