How to remove the headlights SWITCH ???? ( 2001 Mustang )
Old 03-31-2012, 09:27 PM
exisss
exisss's Avatar
Arrow How to remove the headlights SWITCH ???? ( 2001 Mustang )
I know what exactly i have to do. i followed all the tutorials and pictures but it didn't work.
for example they said: "use a tiny screwdriver and move the clip back
towards the nose of the car while pulling on the ****. It's very tiny and
very hard to see how it works while the **** is on. It's a spring clip."
my problem is, i don't see any clip !! inside the hole there are 2 tiny metal rob crossing each other, i have a clear cartoonist picture of how it does look. i tried to pull them in ( 2gether and separately ) but i didn't work...
here is the picture, what i have to do exactly...
( sorry 4 bad English )
exisss is offline
Old 04-01-2012, 09:37 AM
belairbrian
belairbrian's Avatar
your moving the clip the wrong way. To release it you push the clip back towards the REAR of the car.
Done this a few times doing odometer repairs. most recently yesterday.
here is what you're after
belairbrian is offline
Old 04-03-2012, 05:36 PM
JKs95stang
JKs95stang's Avatar
Yup, i've done this a ton of times in both the old 95 and 2000, exactly right small screwdriver toward the rear of the car, the **** will slip right off. Pull on the **** slightly with screwdriver inserted and push towards the rear seat, it will slide off. The rest is two small screws for the bezel(torx if im not mistaken), and two for the actual switch, unplug from wiring harness and replace.
JKs95stang is offline
importsmasher
10-09-2015 04:42 PM
CubanoGT
10-02-2015 10:29 AM
01moostanggt
Suspension
08-13-2015 07:48 AM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: How to remove the headlights SWITCH ???? ( 2001 Mustang )
