what degree timing set on 68 302 engine
Old 04-09-2012, 01:16 PM
Toastintx
Toastintx's Avatar
Default what degree timing set on 68 302 engine
Ok guys manual says 6 BTC my car seems to run better at 10 to 12. Is that ok or or do I have to set at 6. Also what RPM should I be running at idle. I have a mild cam and 625 rpms doesn't seem right
Toastintx is offline
Old 04-09-2012, 03:49 PM
scootchu
scootchu's Avatar
If you car behaves at 10-12° and doesn't ping then I would say leave it. You don't have the stock cam in there anymore.
Do you have an automatic or manual? Bump the idle up a bit. I run mine around 750-800 with a manual. Just my .02.
scootchu is offline
Old 04-13-2012, 09:02 PM
Boxwrenchesareslow
Boxwrenchesareslow's Avatar
also check your overall timing bec you dont want that going much higher then 36*. I have seen some engines though that wanted a lot more overall...like 45, but usually the engine will be pinging by then
Boxwrenchesareslow is offline
drfister
05-03-2018 10:38 PM
1987gt40ttopt
08-28-2015 10:49 PM
prophotog
08-26-2015 11:55 AM
Philhampton1
08-21-2015 12:04 PM
ccwebb
08-11-2015 06:47 PM
Quick Reply: what degree timing set on 68 302 engine
