Old 11-20-2015, 12:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission Guides
Print Wikipost
Tremec t56 swap into 01 GT?
Old 04-26-2012, 06:37 PM
Bpohlman13
Bpohlman13's Avatar
A t56 is prolly out of your budget. If you can find a built 3650 in your price range, thats probably going to suit you better.
Bpohlman13 is offline
Old 05-01-2012, 10:58 AM
blown2001slowgt
blown2001slowgt's Avatar
i got my hands on a 03 cobra t56 trans with 50k miles on it for 1500... it comes with bell housing and a clutch.... all i will need is the cross member and to rewire the harness for the lock out? does anyone have a write up on how to do this? also is it true i need to change the yoke on the drive shaft?
blown2001slowgt is offline
Old 05-01-2012, 11:37 AM
Bpohlman13
Bpohlman13's Avatar
You dont have to wire the lockout up. I didnt when I installed my t56. The only thing it will do is make it hard to push into reverse. You do need the yoke. The transmissions have a different amount of splines on the output.
Old 05-09-2012, 11:02 AM
blown2001slowgt
ok... aluminum drive shaft from 2003 cobra with 26 spline yoke just arrived today along with the crossmember..... the transmission should be here tomorrow along with the clutch and flywheel..... i would like to rewire the lockout since im doing all of this if possible.... any write ups on it?
Old 05-09-2012, 04:44 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Peep the sig, homie
... oops, I don't have it in this sig. Will have to find it and get back to you!
T-56 swap
Jazzer The Cat is offline
Old 05-11-2012, 12:34 AM
Bman2000
Bman2000's Avatar
ok i could be a little confused. first off, i am pretty sure the input shaft on the t-56 is 10 spline, im not sure what you keep breaking on the 3650s but the input shaft would be the weak point in the t-56 tranny. Second, im also pretty sure the output shaft on the tranny to the driveshaft is 31 spline? in either case when i did mine the factory splined gt shaft fits, i just had to have it shortened 1 inch since the t-56 is longer. Honestly i left the reverse lockout unwired, i like having to force it into reverse, means i dont have to worry one bit about somehow gettin it in there by accident.
Bman2000 is offline
Old 05-11-2012, 12:46 AM
Bpohlman13
Bpohlman13's Avatar
some people upgrade to a 26spline input shaft. My output is 31 spline aswell. I plan on wiring the reverse lockout to a switch this weekend since my tranny is out right now from a bad throwout bearing. Thats one thing ive learned on these cars. Never ever put cheap parts on a car where they are hard to replace!
Old 05-11-2012, 11:56 PM
Bman2000
Bman2000's Avatar
sadly buying good parts doesnt save you from premature failing...lol i bought a center force when i did my swap. 500 miles on the nose i went to the track made 2 runs third run the pressure plate failed. had to pull tranny, missed the burnout comp that was the next day. and then i got a replacement, and now it has about 10 thousand miles on it but i dont think its working right. so i wouldnt be surprised if it doesnt hold up to my supercharger.
Bman2000 is offline
Old 05-12-2012, 03:09 AM
  #19
Bpohlman13
Bpohlman13's Avatar
Thats true. I actually have a $125 clutch with my $4000 transmission, and its running grat. i think its kinda funny that i spent so much money on the tranny and so little on the clutch. However I do plan on going dual disc as soon as I finish my motor and put it in. (whenever thatll be)
Old 02-16-2014, 06:47 PM
  #20
ebsterdog
ebsterdog's Avatar
Dude, That is one nice GT. Have you got to the "Aluminator" project yet. I have the same plans for my '02. I had just planned on buying the crate version. Is there money to be saved going your route?
ebsterdog is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: Tremec t56 swap into 01 GT?
