94 GT transmission conversion auto-to-manual
Old 04-26-2012, 10:25 PM
waybackinthastix
waybackinthastix's Avatar
Exclamation 94 GT transmission conversion auto-to-manual
hey guys and girls, im new to the site and i need a little help
im converting a 94 GT transmission from an automatic to a manual transmission
i need help because i have never messed with a tranny and i dont wanna mess up my baby.
i want to do it my self (i have done everything else myself on the car)
Im more than willing to accept help from anyone and everyone, your help is much appreciated!
i will log all of my progress on this site and have a complete start to finnish portfolio of the project for anyone else's future reference
i will begin as soon as i believe i have sufficient knowelege of this project
Your help is much appreciated!!
waybackinthastix is offline
Old 04-28-2012, 12:24 PM
BaltRavens
BaltRavens's Avatar
A tip the T5 is weak, if a new manual is your plan don't go with T5. If you want a solid cheap transmission T56 out of a LT1/LS1. If not that just order a nice manual that can handle a beating and power. You can build something like a g force rebuild kit, and if you're doing a T5 I would suggest that before you put it into a mustang.
That's my opinion, if you're remaining stock I guess nothing wrong with a T5. I just think they're weak transmissions in factory form.
BaltRavens is offline
Old 04-28-2012, 12:29 PM
waybackinthastix
Thank you, im not worried about keeping it stock... that helps alot
Old 04-30-2012, 03:18 PM
88 orangepeel notch
88 orangepeel notch's Avatar
I'm right in the middle of a T5 swap now, just pulled aod out last night. That's one heavy tranny, take your time lowering it. Do a search for T5 swap, alot of info, but the best was the step by step instructions from West Coast web sight, find that, its step one. Good luck.
Old 04-30-2012, 07:47 PM
waybackinthastix
Do you have a link for that?
I been lookimg and i cant find any info so far
Old 05-01-2012, 06:10 AM
88 orangepeel notch
http://www.westcoastmustangs.com/art...ap/t5swap.html
Old 05-01-2012, 10:37 AM
mattdel
mattdel's Avatar
Link is for a foxbody swap. OP has an SN95. Process will be nearly the same, but some crucial details are sure to be wrong.
mattdel is offline
Old 05-02-2012, 05:10 PM
BaltRavens
BaltRavens's Avatar
Should be able the same? They have same rear end, same transmission and same motor, and both are on foxbody chassis?
Old 05-02-2012, 05:13 PM
mattdel
mattdel's Avatar
Yes but the directions in the link are very thorough, showing you which bolts to undo, etc. Those won't all match up in your car.
mattdel is offline
Old 05-03-2012, 08:55 PM
bruehlc
bruehlc's Avatar
Default Different driveshaft
the SN95 is 5/8' difference in length. When I did my 95 vert, I had to have the Drive shaft changed. I think the shaft needs to be shortened. Been 12 years since I did it, but it was not too technical if you have all the right parts. I got my parts from ebay before it went expensive for mustang parts.
bruehlc is offline
4cylinderplus2
10-09-2020 07:45 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: 94 GT transmission conversion auto-to-manual
