Creaky Brake Pedal
Old 04-27-2012, 10:49 AM
EthanP71
EthanP71's Avatar
Default Creaky Brake Pedal
I've seen a few threads about this in the past, but there's never really been a conclusive answer. My 05 has a creaky brake pedal. Usually it only happens when its 75+ degrees out. It's the brake pedal itself, not the brakes.
Anyone else have that? Any remedies?
EthanP71 is offline
Old 04-27-2012, 01:35 PM
Nuke
Nuke's Avatar
Maybe get under the dash and find the pivot points and hit them with some graphite or other lube? I've never looked at it, so that's just a guess. But I may have to look now...
Nuke is offline
Old 04-27-2012, 01:43 PM
lawrencecar1
lawrencecar1's Avatar
lawrencecar1 is offline
Old 04-27-2012, 02:20 PM
Nuke
Nuke's Avatar
I took a peak and there's a heavy guage spring wire as the top pivot point. I'd hit that with a light shot of a lube. If that doesn't cure it, then the suspect is the piston to the power unit.
Nuke is offline
Old 04-27-2012, 07:32 PM
EthanP71
EthanP71's Avatar
Thanks for the pointers. I was planning on lubing something, but I was just wondering if anyones had the same thing and fixed it before. You guys think it matters much what type of lube I use? I was thinking of some white lithium.
EthanP71 is offline
Old 04-27-2012, 10:11 PM
Nuke
Nuke's Avatar
White lithium would be fine PROVIDING that the wire spring is the issue. You might want to try a very short burst of a spray lube (I hate to say WD40) to confirm that it's the spring only becuase I don't like lubing something with a grease only to find that it wasn't the source of the creaking. Regardless of what you use, be liberal.
Nuke is offline
Old 04-28-2012, 11:05 AM
Rylay
Rylay's Avatar
Extra lube won't hurt it, just do one thing at a time so you can narrow it down for anyone else with the problem.
Rylay is offline
Old 04-28-2012, 01:38 PM
Nuke
Nuke's Avatar
Extra lube attracts contaminants which may eventually compound things. Typically, a minor creak only needs a drop of lube.
Nuke is offline
Old 05-05-2012, 10:21 AM
SpartaPerformance
SpartaPerformance's Avatar
NUKE is right a little spritz of white lithium grease should do the trick.
SpartaPerformance is offline
Old 05-05-2012, 08:34 PM
BAB GT
BAB GT's Avatar
I had the same issue over a year ago. Not sure what it was, but I shot everything that could move with a light coat of white lithium grease and it has never done it again.
BAB GT is offline
Quick Reply: Creaky Brake Pedal
