On 2011+s, how is the mpg reading determined?
Old 05-02-2012, 02:02 PM
Andy13186
Andy13186's Avatar
Default On 2011+s, how is the mpg reading determined?
Is the MPG displayed on the dash an overall average of the entire cars lifetime, or just the alst 100 miles? 1000 miles? How is this reading calculated?
Andy13186 is offline
Old 05-02-2012, 02:32 PM
wkayl
wkayl's Avatar
I believe it is from the moment you hit reset. If you are going downhill and hit reset you may reach 99 MPG. If you hit reset while punching it, you may hit 1 MPG.
wkayl is offline
Old 05-02-2012, 02:49 PM
Andy13186
Andy13186's Avatar
I havent hit reset on the mpg screen for like 3000 miles, it was above 18 when i got the car now its 15.5 . I do reset the trip meter every tank though.
HIS S-197
HIS S-197's Avatar
Bingo!
It would be nice if Ford offered a "range" gauge option to let you know exaclty a "live" MPG based on how you are driving at the time.
I know it'd just be fluff in a Mustang but my 1985 BMW 735i has a range gauge and external temperature readout in it.
It could at least be an option, especially given today's economic climate.
HIS S-197 is offline
Old 05-02-2012, 02:52 PM
Andy13186
Andy13186's Avatar
Originally Posted by H-H-YAH
Bingo!
There is a mpg meter with bars rounding to the nearest 5 mpg i think if you go to that screen, i never look at that screen though. It gives the range also, atleast on the 2011's. Fuel warning light comes on at 50 miles to empty and counts down too.
Old 05-02-2012, 03:38 PM
IntentionallyChewy
IntentionallyChewy's Avatar
I calculate mine manually every time I fill up, and the computer is usually about 2-2.5 miles per gallon low. If I reset every time I fill up it's accurate to within half a mile per gallon. I've been told that the computer measures your MPG based on airflow, not fuel flow. I'm not sure if that's correct or not, but it would explain why it's a little off.
IntentionallyChewy is offline
Old 05-02-2012, 05:04 PM
HIS S-197
HIS S-197's Avatar
So that's what those bars mean... the display is not very clear.
The premium '07 IUP dash has the same "50 miles to empty" warning.
I've also noticed that my MPG numbers are a tad off.
Old 05-02-2012, 06:44 PM
Nuke
Nuke's Avatar
NOT resetting the MPG readout results in not seeing any upward or downward trends. I find it best to make it a habit to reset it at each fill-up AND to hand calculate. A vast majority of the 05's-10's were notorious for reading about 1-2 MPG high.
Nuke is offline
Old 05-02-2012, 07:54 PM
outceltj
outceltj's Avatar
Hand calculate it like nuke said the reading is always off a bit.
outceltj is offline
Old 05-02-2012, 08:07 PM
AzPete
AzPete's Avatar
As long as I get to the gas station before I run out, I fill and drive on.....resetting everything. Just a quick mental calculation of the mpg tells me that the car is doing fine.
After all, it is a Mustang.....I would rather watch the rpm's and not the mpg's.
AzPete is offline
mungodrums
Suspension
05-16-2019 09:36 AM
mapitts
05-11-2016 10:14 AM
KingRando
10-01-2015 11:16 AM
mungodrums
09-28-2015 10:54 PM
algregory
09-11-2015 11:44 AM
Quick Reply: On 2011+s, how is the mpg reading determined?
