Not overheating but smells hot??
Old 05-06-2012, 09:26 AM
jlopez07
jlopez07's Avatar
Default Not overheating but smells hot??
Started noticing a hot smell in the cab of my car the other day. Usually starts after I get at higher speeds. Car isn't running hot and there's no smoke in engine bay. No puddles either, other than the normal a/c condensation on ground. No leaks inside under dash as 2ell. Any ideas???
jlopez07 is offline
Old 05-06-2012, 10:52 AM
2005Redfire6
2005Redfire6's Avatar
Could be anything but if its not leaking, smoking, over heating I wouldn't worry about it.
2005Redfire6 is offline
Old 05-06-2012, 05:24 PM
Rshustler1
Rshustler1's Avatar
Do you have a Morison coolant tank? Cause if so it will produce the heated coolant smell
Rshustler1 is offline
Old 05-06-2012, 09:00 PM
flyhigh@mach1
flyhigh@mach1's Avatar
Is your car a standard or auto? You could be smelling your clutch if your getting on it or brakes if your using them hard?
flyhigh@mach1 is offline
Old 05-06-2012, 09:36 PM
CPTCO
CPTCO's Avatar
Here's an off the wall idea. A few years back, I was driving my Corvette down the highway. A lawn fertilizer bag kicked up and stuck to my hot exhaust. I was forever getting that stupid thing off. Car smelled like burnt plastic every time I drove it.
CPTCO is offline
Old 05-06-2012, 10:40 PM
2005Redfire6
Ahh yes very good point! Happened to a friend and it smelt exactly like that.
Old 05-07-2012, 01:08 AM
jlopez07
jlopez07's Avatar
its an automatic. Im starting to thinking maybe it is either the clutch or the brakes. I had about 500 extra pounds in the car thanks to two passengers the other night and i pulled out from a gravel road at an incline to pull onto the highway and the car revved up high. I only notice the weird smell when the car gets up to temp.
jlopez07 is offline
Old 05-07-2012, 01:21 AM
jlopez07
jlopez07's Avatar
Resevoir is the stock one. Transmission isnt skipping or hesitating as well.Fluid levels are on spot. No oil in coolant and no coolant in oil so its not a gasket. Car runs fine, just that hot smell is getting me paranoid. Im actual starting to smell the smell everywhere now lol
jlopez07 is offline
Old 05-07-2012, 11:00 AM
157dB
Cut & Paste Expert
157dB's Avatar
[b]its an automatic.
or the brakes.
Autos dont have clutches....
157dB is offline
Old 05-07-2012, 03:41 PM
jlopez07
jlopez07's Avatar
Ya I know lol. But I started thinking more an more and I do remember having a case that the water bottles come fly under my car and the smell is that of plastic. Gonna jack the car up and look under just to be safe though.
jlopez07 is offline
Quick Reply: Not overheating but smells hot??
