Old 10-12-2015, 02:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
omg...convertible top leaking..how can i fix it?
Old 05-11-2012, 02:02 PM
sjpark
sjpark's Avatar
Default omg...convertible top leaking..how can i fix it?
Hi..
I have 2004 mustang convertible v6.
Few days ago, I found that My convertible top starting leak of passenger seat.
I found where is leaking. but I dont know how can I fix it..
Leaking spot is passenger side speaker, and small window.
pls advice me.
sjpark is offline
Old 05-11-2012, 03:31 PM
slonison
slonison's Avatar
sjpark, where in nj are you located?
slonison is offline
Old 05-11-2012, 03:36 PM
Old Mustanger
Old Mustanger's Avatar
Search around and find a good top installer, they should be able to guide you in the right direction. A conv top is a specialty, the wrong person working on it can really screw it up.
Never take it to a dealer unless they have a separate conv dept.
If you are a DIY kinda guy, give this a try:
http://www.fordsunlimited.com/fords_convertible.html
Old Mustanger is offline
Old 05-12-2012, 10:48 AM
sjpark
sjpark's Avatar
Default .
I'm located in palisades park. north burgen.
sjpark is offline
Old 05-12-2012, 10:50 AM
sjpark
sjpark's Avatar
Default .
> Actually I already change it by myself.
sjpark is offline
Old 05-13-2012, 10:36 PM
slonison
slonison's Avatar
Yea, it's been raining a lot around here. I actually changed my entire top myself (both parts)... took a few days from start to finish.
How did it go? Does it still leak?
slonison is offline
Old 05-14-2012, 12:56 PM
sjpark
sjpark's Avatar
Default .
Yea. I had fix it.
The problem is headlinner. you know, I dont know the word, like a silicone.
Some silicone had screw up. So I fill it up silicone where the hole on my head-linner.
sjpark is offline
Old 05-23-2012, 07:03 PM
sjpark
sjpark's Avatar
Hey.
Did you find it out?
You got a same problem with me?
My car save a lot of water in passenger rear floor.
first of all, I just thought that It must be sealing problem around windows.
But it's not.
And next I'm suspecting the quartor seal. But It was also wrong..
Today I searching a lot of article in google.
finally I got it!!!
It just skirt!!!!Can you belieave that?
After rain.. Skirt save a lot of water in here. futher more it will be flood at back seat. you can see the hole when lift your backseat.
The water came over here!! I'll make a hole under my skirt tomorrow.
And Here's original article link.
GOOD LUCK!!
http://www.stangnet.com/mustang-foru...-floor.805787/
sjpark is offline
Old 06-27-2012, 02:15 PM
dgaiser
dgaiser's Avatar
I'd take it to someone who works on tops and can water test it. Blue Sky Custom in West Caldwell did my top and the guys there know there stuff and are nice. They might be able to give you advice if they're run into the same problem.
dgaiser is offline
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
jc409
Convertible Tech
09-24-2015 03:38 PM
AMAlexLazarus
AmericanMuscle.com
09-23-2015 01:14 PM
Mr. D
09-16-2015 11:04 PM
Quick Reply: omg...convertible top leaking..how can i fix it?
