gt brake conversion / upgrade
Old 05-19-2012, 11:04 AM
157dB
Cut & Paste Expert
157dB's Avatar
Originally Posted by Joshspony
Thanks 157dB, but I have 17" wheels and don't plan to change to 18's anytime soon. If I did have 18's I would be all over it.
Let me figure out what I'm doing for rotors and I'll let you know about the brackets. I might just get the bracket/rotor upgrade kit from AM. But if I go with slotted rotors I will buy your GT brackets.
Maybe I dont understand your answer but here goes nothing...
GTs came with 17s OEM and the 12.4" rotors will fit under OEM 17s.
18s are only needed for the 13.2" brake conversion.
The 12.4" 2005-2010 GT caliper brackets are here when you need them....
157dB is offline
Old 05-19-2012, 11:42 AM
tx_zstang
tx_zstang's Avatar
I used one of the conversion kits with the stock GT rotors. Yeah, not the best choice if you want different (slotted) rotors. But everything worked out fine otherwise.
tx_zstang is offline
Old 05-10-2014, 08:49 PM
Rickoshay
Rickoshay's Avatar
I just completed a conversion on my 06 GT, using the Roush 13.2 in. rotors & bracket take off parts. My choice was the OEM Bullitt/GT500 Carbon Metallic pads to go with this setup.
This combination really worked for me, my driving is a daily driver & also mountain roads on the weekends.
IMO, This combination works like gangbusters for me!!
Rickoshay is offline
Old 05-20-2014, 10:22 AM
Mustangarrett
Mustangarrett's Avatar
Where did you buy the takeoff parts? I'm interested in the same conversion, but have had a hard time finding anything not too expensive. Thanks
Mustangarrett is offline
Old 05-21-2014, 02:51 PM
Rickoshay
Rickoshay's Avatar
You can buy the take off parts from either the Roush on line store, or there Roush Ebay store.
The OEM 08-09 Bullitt/ 07, 08 & 09 GT500 (Non Brembo) carbon Metallic front & rear pads I bought from my Ford dealer. I can look up the pad numbers if you need them.
Hope this helps
Old 05-21-2014, 03:09 PM
Rickoshay
Rickoshay's Avatar
Added Note For Post Above:
Ford OEM Carbon Metallic pad part numbers.
Front Carbon Metallic pad set 8R3Z-2001-A (Part interchanges with Motorcraft #BRF1081B)
Rear pad set 7R3Z-2200-A (Part interchanges with CR3Z-2200-A)
Old 07-26-2014, 10:35 AM
SteveDwsn
SteveDwsn's Avatar
What he said. I would also add, unless it has been done recently, take an extra hour, flush all the old brake fluid out, and replace it with new. You are already there, so why not? Honestly, new fluid made more of a difference in my braking than the upgrade did.
SteveDwsn is offline
mungodrums
10-07-2015 04:01 AM
67LimeCoupe
09-21-2015 06:34 PM
tj@steeda
Steeda Autosports
09-08-2015 11:50 AM
Quick Reply: gt brake conversion / upgrade
