Ideal front camber setting?
Old 05-22-2012, 05:29 PM
Andy13186
Andy13186's Avatar
Default Ideal front camber setting?
I had steeda sport springs and koni sport dampers installed and they did a "performance alignment" . Car ended up with some camber in the front. I wasnt expecting any without having bought C/C plates but there definatly is some. I am wondering if this will just wear my tires out faster or actually provide some benefits.
you can see the camber here
it looks kind of minor in the pics, but it looks more noticible from other angles
Andy13186 is offline
Old 05-23-2012, 06:16 AM
Norm Peterson
Norm Peterson's Avatar
I hate to sound crotchety this early in the day, but I'm positive that your shop told you they "gave you a performance alignment" because they couldn't fix the visible camber that resulted from the lowering without buying and installing different parts and/or adding labor. That would have meant camber plates, Steeda HD strut mounts, "camber bolts", or by some other sort of modification. All because there is no built-in camber adjustment. What they did was no more of an alignment job than resetting the toe (if they even bothered to do that).
These cars do come off the production line with a little negative camber - it's intended to be -0.75° but is allowed to vary half a degree to 3/4 of a degree either way from there. At -0.75° you probably wouldn't notice just by eyeballing it, at
-1.5° or so most people probably would.
Lowering these cars will always make the camber go more negative, and a 1.25" lowering will make the camber go about 3/4° more negative than it was before lowering. So it's no surprise that you notice it now but didn't before.
There are several DIY methods of measuring camber (I'm being absolutely serious about the DIY part), and once you find out what it is and define just how hard you're going to be taking the car around corners you can decide what - if anything - you're going to do about it.
FWIW, I'd rate camber in the range of -1° to maybe -1.2° as being mild to moderate performance specs (in which case most people don't need to do anything), and driving daily on anything past -1.5° as getting up into hardcore corner-carving territory (where you'd probably want to correct it if this does not describe a significant portion of your driving).
Camber being a little off isn't as hard on tires as bad toe, so at least for the short run it shouldn't be a problem wear-wise.
Norm
Norm Peterson is offline
Old 05-23-2012, 12:48 PM
Entaille
Entaille's Avatar
I mirror Norm's sentiments. if it bothers you, you'll have to get hardware to correct it. there are a lot of solutions out there. they probably claimed a 'performance alignment', because they couldn't get the front back into spec. hopefully they corrected the toe at least.
did they give you before and after printouts of the alignment? perhaps we can help more with that information.
Entaille is offline
Old 05-23-2012, 12:55 PM
Andy13186
Andy13186's Avatar
Thanks for the info. They did not give me a print out. The car was lowered onto steeda sport springs which are 1 inch lower in the front 1.25 inch in the rear. Car does feel different when doing U turns. Ill try it out for a while with this setting i suppose. I do very little corner carving, i live in Florida and most roads are just straight lines but I wouldnt mind having a bit extra maximum cornering performance potential if it doesnt negatively effect anything too much.
Old 05-24-2012, 09:26 AM
Andy13186
Andy13186's Avatar
I hit a manhole cover and now my steering wheel seems to be off a bit. Im not sure if it was slightly off before or not but when i have it perfectly straight, the car turns to the right. The shop said the suspension may settle a bit and they will look at the alignment again.
Should a decent size manhole cover bump be able to mess up alignment? I was hoping alignment would stay how it was set even after hitting those type of things.
Ill have it back there within 2 days.
Old 05-24-2012, 11:35 AM
Andy13186
Andy13186's Avatar
you can see the major camber difference from this
Old 05-25-2012, 11:30 AM
12GTPDX
12GTPDX's Avatar
Can't comment on the manhole cover putting the alignment out of whack, but generally speaking, when installing lowering springs, they will settle in over the first couple of weeks after install -- it's common to let this settling take place before getting the car aligned post-lowering.
12GTPDX is offline
Old 05-25-2012, 04:01 PM
Andy13186
Andy13186's Avatar
took it back to the alignment shop and they said the front right was 2.1*, front left 1.3*
so i need camber bolts.
Im looking at the eibach camber bolts
http://www.stranoparts.com/partdetai...205&ModelID=35
hope these will work with the 2011+ specific koni's, anyone know for sure?
Old 05-25-2012, 07:33 PM
corruptor
corruptor's Avatar
Are you on GT500 strut mounts? Apparently you can reduce the negative camber depending on which way the strut mount arrows are pointing.
corruptor is offline
Old 05-25-2012, 08:38 PM
Andy13186
Andy13186's Avatar
no, stock 2011 strut mount(or w/e 2011 stock is), with the new 2011+ specific koni sports.
Quick Reply: Ideal front camber setting?
