Sponsored by: DashLynx
Gear lever stuck in park
Old 05-29-2012, 06:14 AM
petter
petter's Avatar
Default Gear lever stuck in park
Started my 99 GT as usual. No problems starting but could not move the gear lever from park. Tried pumping the brake but still stuck. Also tried to disconnect the battery for some hours but still stuck in P.
Any tips or tricks please?
petter is offline
Old 05-29-2012, 06:35 AM
GreyStang
GreyStang's Avatar
Were you parked on a hill?
Try shifting gears with the engine off...
GreyStang is offline
Old 05-29-2012, 08:51 PM
craig71springsport
craig71springsport's Avatar
^^perfect reason to use parking brake!^^
If you did park on a hill, it puts a load on your transmission if you didn't use your hill brake. Therefore you are going to have to move the car forward, or backward depending on if you parked uphill or downhill, to be able to disengage your brake. I did this once and it was the only way I could get it out of gear.
If you didn't park on a hill, maybe you snapped a band or something? I don't know much about auto trannies.
craig71springsport is offline
Old 06-02-2012, 07:28 AM
Jfsram
Jfsram's Avatar
Do your brake lights work?
Try turning the key one click short of on. See if you can shift out of park now.
Jfsram is offline
Old 06-03-2012, 03:58 PM
nickel417
nickel417's Avatar
Check the brake sensor wire on the top of the brake pedal and see if it is broke. On my 01 Auto the wire broke and did the same thing. I was able to fix it myself
nickel417 is offline
Old 06-04-2012, 08:41 AM
petter
petter's Avatar
The car is parked on a flat space. The brake lights work. Have not yet checked the sensor wire. Seems to be some wiring connected to the break pedal. Can you please detail what to look for?
petter is offline
jstrothe
09-24-2015 12:17 PM
musnicki
09-23-2015 07:11 AM
rafotree
09-22-2015 03:55 PM
LivingInThePast
09-16-2015 12:20 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: Gear lever stuck in park
