1965 Mustang Wiring and Vacuum Diagrams
Old 09-21-2005, 11:42 PM
kallador
kallador's Avatar
Default 1965 Mustang Wiring and Vacuum Diagrams
i needed the diagram for my 65's instrument cluster and found this good stuff here http://www.hammar.dyndns.org/wiring/wiring1965.htm
kallador is offline
Old 09-21-2005, 11:48 PM
tylerdru
tylerdru's Avatar
Default RE: 1965 Mustang Wiring and Vacuum Diagrams
WOW, I really need that as none of my interior lights work.
tylerdru is offline
Old 09-21-2005, 11:55 PM
kallador
kallador's Avatar
glad it helps ya i said WOW also when i found it lmao unsure how compleate/incompleate it is but i found where my constant voltage unit behind dash is for my gauges
kallador is offline
Old 09-22-2005, 12:02 AM
tylerdru
tylerdru's Avatar
hmm now i must start to figure out why my lights dont work. Fuses are good and light bulbs are new.
tylerdru is offline
Old 09-22-2005, 12:55 AM
Scott H.
Scott H.'s Avatar
Great find!,
looks like it goes all the way to '68.
Scott H. is offline
Old 09-22-2005, 01:02 AM
nualln
nualln's Avatar
Those helped me when I re-did my A/C vacuum lines, but either my switch is bad or that document is wrong, because it didnt work the way they had it laid out. 2 of the vacuum lines are attached to the wrong nipple at the switch.
nualln is offline
Old 09-22-2005, 05:35 AM
Soaring
I ♥ Acer
Soaring's Avatar
Great find. Shall I make it a sticky, or add it to something on top?
Soaring is offline
Old 09-22-2005, 01:28 PM
nualln
nualln's Avatar
You could add it to: speedometer gear information and 1965 wiring diagrams.
nualln is offline
Old 09-22-2005, 01:33 PM
Soaring
I ♥ Acer
Soaring's Avatar
I already added it to the speedometer gear information. So, it will be there in the future for all us with that model.
Soaring is offline
Diode Dynamics
28
05-26-2022 12:02 PM
ShaneB26154
35
03-04-2021 04:05 AM
importsmasher
10-09-2015 04:42 PM
Philhampton1
08-21-2015 12:04 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 1965 Mustang Wiring and Vacuum Diagrams
